welp, i'm boned. broke crank hub while on the car
Old Aug 16, 2004 | 04:30 PM
  #16
Z95m6's Avatar
Re: welp, i'm boned. broke crank hub while on the car
yes the caprice hub is diff. I bought a caprice short block to build up to put in my Camaro and when i got the motor in the pulleys didn't line up and it was because the hub is diff. I believe the caprice hub is longer or something because it wouldn't work with my Fbody pullies.
Originally Posted by Fux0redImages
I'm looking at the two crank hubs I have, is there a difference between the Caprice LT1 hub and the F-Body LT1 hub. They're shaped slightly different, but I can't imagine them being any different.
Old Aug 16, 2004 | 05:29 PM
  #17
Fux0redImages's Avatar
Was it the balancer wouldn't go on or the belt? I need to use the caprice one to go to the machine shop for the peice I need to get this thing off. Are the bolts gonna line up? I'm hopin just the hub was too long, so the belt wouldn't go on right.
Old Aug 16, 2004 | 05:59 PM
  #18
Z95m6's Avatar
it was over a year ago. I believe that the hub was too long and so the belt wouldn't sit on the balancer. We couldn't get the caprice hub off and since i didn't need it, my dad took an air chisel off and hammered on the hub on all sides until it came off.
Old Aug 16, 2004 | 06:34 PM
  #19
Worst install, ever.
Old Aug 20, 2004 | 10:27 PM
  #20
Well, great after about a week of fiddling with this god damn thing after work. I grinded down a lip to attach a 3 jaw puller onto. Well, what a suprise it broke. That's right a 2 ton 3 jaw puller broke. So, I went back to auto zone and got the 5 ton 3 jaw puller, but there's absolutely no way to get it to work. It's just too big, there's no way for it to get a good grip. I'm thinking tomorrow, I'm gonna go get another 2 ton and try again. If it breaks again, I'm cutting it down the middle even more taking a ****ing chisel and splitting the son of a bitch down the middle. I'm running out of options here, anyone?
I figured people would want pics, here we go. Here's what my crank hub looks like now...
http://members.aol.com/webbenizer/hub.jpg
Here's the POS 2 ton 3 jaw puller, you can see the crack in the prong.
http://members.aol.com/webbenizer/puller.jpg
Sure glad I dropped that 1000 on a cam and opti.
Old Aug 20, 2004 | 11:03 PM
  #21
97WS6SCharged's Avatar
Just get a torch and heat it up, then use a pair of welding gloves to pull it off.
Old Aug 20, 2004 | 11:10 PM
  #22
JBirdSS's Avatar
You're going to win this battle just hang in there. Once you get the puller installed and ready to go add the heat to the hub. Also, have someone else hitting the hub with a ballpeen hammer to add some shock load to the hub. Make absolutely positive sure your bolt in the center of the crank that the puller is pushing against hasn't bent and a bit too short. Pulling pressure, heat and shock...you are going to win.
Old Aug 20, 2004 | 11:28 PM
  #23
CamaroRob97's Avatar
Damn man that sux!! I remember when i was try to get mine off and that mother...(fill in the blank ) I thought it would never come off let alone break an ear off like that!! Best bet is probably call a mobile welder and see what he says before you go any further! Best of luck!!
Old Aug 20, 2004 | 11:39 PM
  #24
I don't have a heating gun or the money to buy one. I'll try to borrow one and see what happens.
Old Aug 21, 2004 | 04:10 PM
  #25
Finally, it's off. I broke another 3 prong puller, so I flipped it around and tried the other side. It FINALLY came off. Here's some pics of the hub all hacked up.
http://members.aol.com/webbenizer/HubOff.jpg
http://members.aol.com/webbenizer/HubOff2.jpg
Old Aug 21, 2004 | 07:22 PM
  #26
JBirdSS's Avatar
Today's results just in from Athens, Greece: in the Hub Removal competition.
Final score; Fux0redImages - 1, Lt1 Hubs - 0.
Congratulations on a well earned Gold medal. Savor your victory.
Queens94z28
Dec 20, 2014 09:11 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
1LEThumper
Jul 14, 2003 12:45 PM
