View my Datamaster file
Old Dec 9, 2008 | 08:46 PM
  #46
TBSPW's Avatar
simple solution wire your fans up to a manual switch like i did...works great and i have never had a problem
Old Dec 9, 2008 | 09:40 PM
  #47
Originally Posted by cblinkdude182
How do I check that?
Try a local shop or auto parts store. They put it on a hand pumped pressure tester.
Old Dec 10, 2008 | 11:48 AM
  #48
01pewterz's Avatar
Originally Posted by Injuneer
Did you check your radiator cap, to make sure it can hold the factory rated 18psi? If it can't hold the pressure, it lowers the temperature at which the coolant starts to boil.
Ditto,
Had same problem on my LS1, replaced cap fixed it!!!
Old Dec 13, 2008 | 05:04 PM
  #49
cblinkdude182's Avatar
Got my radiator cap tested and it holds a little over 4 psi, lol. So I definitely need to replace that...
NewsBot
Sep 30, 2015 04:20 PM
jayblev95
Sep 26, 2015 09:44 PM
NewsBot
Sep 15, 2015 11:53 AM
NewsBot
Sep 14, 2015 02:02 AM
tommalcolm
Sep 11, 2015 03:39 PM
