Push rods Stock Length?
Old Dec 10, 2008 | 11:28 PM
93FIRETURD's Avatar
I am putting the lt4 hot cam and 1.52 roller tipped rockers i know i will need hardened pushrods but will stock length work with decked heads? Any help is appreciated
Old Dec 11, 2008 | 12:36 AM
Romero155's Avatar
Will if you decked your heads you should check the length with a PR length checker just to be on the safe side. They arent that much money and Comp Cams makes a pretty easy to read one
Old Dec 11, 2008 | 01:08 AM
93FIRETURD's Avatar
yeah i thought so thanks
Old Dec 12, 2008 | 01:03 AM
94Z28rag's Avatar
Hotcam = 1.6 RR's
Do a search...just trying to help you out.
Old Dec 12, 2008 | 02:51 AM
6SpdLT1Z's Avatar
Originally Posted by 94Z28rag
Hotcam = 1.6 RR's
The cam doesn't determine the ratio of the rockers.
Always measure and determine your PR length to be sure. I believe the tool is $20.
Old Dec 12, 2008 | 07:47 AM
If you are not using guideplates, hardened pushrods are not required.
Old Dec 13, 2008 | 01:34 AM
93FIRETURD's Avatar
ok well i guess i'm not sure if i'm using guide plates but my buddy has the tool for checking the pr length i am however unsure of the proper procedure for doing so any more help would be appreciated greatly thanks
Old Dec 13, 2008 | 10:17 AM
http://www.carcraft.com/techarticles...gth/index.html
Old Dec 13, 2008 | 10:30 PM
93FIRETURD's Avatar
thank you guys so much for the help your expertise far surpasses mine thanks guys
Old Dec 13, 2008 | 10:37 PM
You wouldn't be asking questions if it was the other way around, eh?
Old Dec 13, 2008 | 10:54 PM
6SpdLT1Z's Avatar
Shoebox ftw.
oldschool
Feb 9, 2016 09:21 PM
nikolt1
Feb 27, 2015 09:10 PM
ModdedNerd
Feb 5, 2015 04:37 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
