Very pleased with 1.6rr's
Old Aug 12, 2004 | 09:16 PM
  #16
LT1Squirrel's Avatar
Re: Very pleased with 1.6rr's
# 12495494
$26.47 off of GMPD
Old Aug 12, 2004 | 09:21 PM
  #17
LWillmann's Avatar
Originally Posted by 9T4Z28
hey LT1 squirrel do u know the GMPD part # for the lt4 springs? thanks, and for the Comp pushrods wha do you guys suggest, i seen a thing taht said "Comp cams high energy pushrods for 55-UP Small block flat tappet sold in set of 16" or do i go with the "Comp cams high energy pushrods for 87-UP OE Small block roller cams sold in set of 16"? For the 1.6 rr's is Crane Cams Gold's the best? how much should this all run me. thanks guys i really appreciate the help
Dan
you want the roller cam set of hardened pushrods.. Like $40 or so.
Old Aug 12, 2004 | 09:30 PM
  #18
9T4Z28's Avatar
Thanks guys really appreciate the info!
Old Aug 13, 2004 | 02:32 PM
  #19
jasons93z's Avatar
Originally Posted by Compstall
Everyone talks about gains, but what exactly did you gain? I got 7 rwhp and 2 lbs torque on the dyno.
Imn pretty sure i gained more than 7rwhp. Its a VERY noticible gain.
Old Aug 13, 2004 | 03:07 PM
  #20
Pasky's Avatar
average gain is usually 14 rwhp.
Old Aug 13, 2004 | 03:11 PM
  #21
LWillmann's Avatar
I would LOVE to see a 14 RWHP gain out of just rockers and springs!
Old Aug 13, 2004 | 06:16 PM
  #22
Compstall's Avatar
I don't believe in the butt-dyno, unless it's something like N20, but then you STILL don't know HOW MUCH you gained.
We can bench race power #'s all day long, the proof is on the rollers.
Old Aug 13, 2004 | 08:15 PM
  #23
jasons93z's Avatar
I didnt say **** about a butt dyno. You said you gained 7rwhp. All i said is it felt like more than that. I remember when i put on the moroso cai and i didnt fell this much gain. So im guessing i gained a good amount, thats all. Cars react differently to modifications.
Old Aug 13, 2004 | 08:19 PM
  #24
jasons93z's Avatar
BTW, my local engine guy said the average gain with rr's and springs is 20-30 front end horse power. According to a %15 loss that would be anywhere from 17-25.5rwhp. Depending on mileage. He builds lt1's and ls1's all the time and owns the shop "From mild to wild" and dynos every car he builds. So i think i trust him..
Old Dec 16, 2004 | 05:39 PM
  #25
Bersaglieri's Avatar
What brand RR did you use? Still feel the same way about your gain?
-Dustin-
Old Dec 16, 2004 | 06:24 PM
  #26
hsyr's Avatar
Originally Posted by RE AND CHERYL
1.7RR on stock heads are a waste. The stock intake port stalls out around .500 lift and the stock exhaust around .525, also the flow increase from .400 to .500 is nothing to write home about. If your heads are stock, I would stick with 1.6RR.
I was told the stock springs are good for .500 lift (is this right?). My calculator says 1.6RR would put me around .475. Am I wrong to think that this is enough. I do realize that older springs are weaker and will float earlier because of it. This is one reason I have backed off my rev limiter to 5k until I get my heads/cam done over the winter.
1.7s are a waste? Then why do people make more power with them over 1.6s on stock heads?
z28leno
Mar 12, 2015 07:42 AM
Bigbraxx
Aug 12, 2002 05:17 PM
Carguy00
Aug 6, 2002 10:25 PM
Burmite
34
Jul 5, 2002 12:00 AM
Burmite
15
Jul 3, 2002 11:40 PM
