Vats issues
Old Nov 4, 2018 | 04:24 PM
Jdalrymple's Avatar
Vats issues
I've done the resistor and even bought a vats bypass module .Still no injector pulse . I've done everything the internet suggested I'm running out of ideas and tired of waisting money. Its not the optispark .The code reader I bought says vats failure. Security light isn't on but I'm still getting a vats code and no injector pulse
Old Nov 4, 2018 | 07:49 PM
Re: Vats issues
Have you cleared the code? What year is your car?
Old Nov 4, 2018 | 10:03 PM
GaryDoug's Avatar
Prominent Member
Re: Vats issues
It may be a failure of the VATS module itself. The code is saying it doesn't receive the "ok" signal from the module; but if it's bad, that could be why. There are VATS full bypass kits and methods that can eliminate the module itself if you can't find another one. The bypass kit substitute module sends a signal to the PCM that copies the one from the VATS module.
Old Nov 4, 2018 | 10:58 PM
Jdalrymple's Avatar
Re: Vats issues
Its a 93 z28. And I bought the full bypass module just not sure if I'm hooking it up right
Old Nov 5, 2018 | 12:10 AM
Re: Vats issues
Make sure you follow the instructions for the 30 Hz signal, only used in 1993.
Here's the VATS system wiring diagram. 93-95 are all similar.
Courtesy of Shoebox
http://shbox.com/1/pass_key.jpg
Old Nov 5, 2018 | 12:35 AM
Jdalrymple's Avatar
Re: Vats issues
My issue is that I don't understand wire diagrams . I was hoping someone has used this module I bought and can tell me where to hook it up (location and wire color) I can't make out a bit of what diagrams are trying to explain .I'm dumb when it comes to that stuff
Old Nov 5, 2018 | 03:24 PM
Re: Vats issues
The factory theft deterrent module or TDM (the 1993 factory manual labels it as the "PASS-Key Decoder Module) is located "in instrument panel, just to right of the radio, attached to the air bag bracket".
I have not personally installed the new module you have, but based on the instructions you posted above, and the 1993 factory service manual, here is what needs to be done.
You need to attach the red wire to a switched12 volt source. When you find the theft deterrent module, there will be a 16-pin connector attached to it. Pin A2 is a pink wire, and that is switched 12 volts from fuse #5. Do not cut this wire. Leave it in the connector and splice the new module red wire into it.
You need to attach the black wire to a ground. In pin B5 there is a black/white wire that is a ground. Or you can attach the black wire to any grounded metal under the dash. If you want to use the black/white wire do not cut this wire. Leave it in the connector and splice the new module black wire into it.
You need to attach the white wire to the ECM input wire. On a 1993 V8, the fuel enable signal wire is dark blue. That wire starts in pin A3 of the TDM connector. Cut that wire off at the connector, and attach it to the white wire in the new module.
The instruction for the blue-green wire appears to have been translated from Chinese, or something, and isn't crystal clear. The way I interpret it, since you have to have the 30 Hz signal for a 1993, the blue-green wire needs to be attached to a ground. But where they refer to a blue-green wire at the beginning of the instruction, the last part only mentions a blue wire needing to be attached to ground. From the picture, appears there are both a blue wire and a green wire, so you can see the source of confusion.
Old Nov 5, 2018 | 03:28 PM
Re: Vats issues
Be sure to re-read the above, before making a copy of it - I had to make a couple changes after I proof-read it.
Old Nov 5, 2018 | 04:49 PM
Jdalrymple's Avatar
Re: Vats issues
Still no luck. My next move is a piggybacking chip for the prom chip to delete vats if this don't work then I'm thinking the computer is shot
Old Nov 6, 2018 | 10:17 AM
Jdalrymple's Avatar
Re: Vats issues
I got the bypass module to work. My camaro lives
Jdalrymple
Nov 21, 2018 01:31 PM
jlmeraz
Nov 12, 2007 03:55 PM
Rage
3rd Gen / L98 Engine Tech
May 5, 2006 10:31 AM
fve253
Jan 25, 2006 06:14 AM
samualt
Sep 18, 2005 02:05 AM
