Baker Electronics VATS bypass module: Have you used it?
I am using the VATS bypass module form Baker Electronics and my car will crank, start and sputter. Has anyone else used this module? Did it work for you? How did you wire it?
Re: Baker Electronics VATS bypass module: Have you used it?
easiest way is to measure the ohms of the pellet in your key then insert resistors that equal it into the connector under your steering column
