Vac. pumps
Old Apr 2, 2008 | 01:23 PM
  #16
mzgp5x's Avatar
Pics... Vac pump application.
Hope you can link.
Application... 97ss/ 383ci/ LT1/ D1 procharger/ M6.
Vac pump crank drive located on Rt (passenger side).
Rad move was required for this mod.
Retained surpentine belt drive on Rt side. Yes, belt can be removed without disassembly of the vac pump.
B.
http://s306.photobucket.com/albums/n...partsO_all.jpg
Old Apr 2, 2008 | 02:18 PM
  #17
1redTA's Avatar
re
ask Dave (Fast Fat Boy) how Clyde had his Aerospace vacuum pump on that motor. I remember that he had no acceseries so it was probally much easier for him. Art p.s. Clyde said your car was pulling good times for the smaller cam and pump gas. Are you still on the same converter. he had a ~5000 stall and 4.88 gears with the bigger cam though when he went 10.40. you were moving pretty well for the current set up
Old Apr 5, 2008 | 03:30 AM
  #18
tlillard23's Avatar
mzgp5x: you must have been a tinkertoy kid... Show us some pics of that hog doing some wheelstand burnouts. I'd have to ride in that thing to see if it really works......
T
Old Apr 5, 2008 | 08:30 PM
  #19
tapout911's Avatar
I got it all worked out and is mounted clean and pretty. I had to have the mandrel machined to be 1 inch shorter to get belt alignment right. Heres a pic from mock up
Old Apr 5, 2008 | 08:33 PM
  #20
mdacton's Avatar
I like how that looks, I have the same Wpump and alt. set-up.
What kit is that?
Old Apr 5, 2008 | 08:37 PM
  #21
tapout911's Avatar
The vacuum pump kit all come from GZ motorsports http://www.gzmotorsports.com/index.html Basically just a sbc kit. Came with everything needed.
Old Apr 5, 2008 | 08:53 PM
  #22
mdacton's Avatar
tapout what mandrel did you end up going with?
And did you redrill and tap the heads for SBC intake pattern?
I want to go ahead and get that kit
Old Apr 5, 2008 | 09:02 PM
  #23
tapout911's Avatar
They sent me a long mandrel, was 4 inches from the end to the center of the belt groove. Needed to be 3". I had the tool room at my work machine it down for me. Might have been for a long water pump set up, idk. It bolts to the balancer with a longer crank bolt. Didnt touch the heads, just the intake holes. They were really helpful at GZ and it only took a few days to get my kit.
Old Apr 6, 2008 | 11:13 AM
  #24
Hope you can link.
B.
Is that gigantic aluminum cylinder with the spring the vacuum relief valve?
Old Apr 6, 2008 | 11:20 AM
  #25
mdacton's Avatar
http://www.gzmotorsports.com/vacuum-control.html
They show different ones so I would like to know too........I want the smallest one possible.
HectorM52
Jul 30, 2017 11:46 AM
4586
Apr 24, 2015 01:03 PM
ANDYZ28
Dec 29, 2014 09:13 PM
pologreen97z
Dec 2, 2014 10:42 AM
Jibberish18
Apr 18, 2002 01:19 AM
