Two plug wire questions: Routing and salvaging
Old Jul 19, 2005 | 11:46 PM
Black1995Z's Avatar
Arrow Two plug wire questions: Routing and salvaging
I took a pic of the routing on the driver's side. Can anyone verify this is correct? It seems to work the best.
http://members.***.net/1995z28/PROPERROUTEidk.jpg
Also, one of my wires is torn, not badly enough to see an actual wire. Can this still cause problems? These are new and I dont want to replace them again. I have heard of users using electrical tape to repair them. Would that keep the negative effects from happening?
http://members.***.net/1995z28/TORNWIRE.jpg
Old Jul 20, 2005 | 12:13 AM
transamdude95's Avatar
Re: Two plug wire questions: Routing and salvaging
[url]http://members.***.net/1995z28/PROPERROUTEidk.jpg[/url
If you have the stock manifolds, I think they go in the metal holder that runs under the manifolds. Looks ok if you keep them away from heat.
I'd replace it. I'm not sure how well taping it up would do, but maybe others have tried it that can comment.
Old Jul 20, 2005 | 01:00 AM
SoloExceptional's Avatar
Someone correct me if I'm wrong but electricity takes the path of least resistance(as do most things in life ) and since I'm pretty sure the resistance of electrical tape is far less than plug wire insulation., I would think you would still run the chance of losing spark and arching against something metal.. I, personally, would just replace them. Besides, if that electrical tape gets near anything hot it'll melt and smell bad
Old Jul 20, 2005 | 01:46 AM
Black1995Z's Avatar
What about the routing, is it correct for the #7 wire?
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
grabbem88
Mar 18, 2015 01:25 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
grgguy
17
Feb 23, 2015 07:57 PM
