Two plug wire questions: Routing and salvaging
I took a pic of the routing on the driver's side. Can anyone verify this is correct? It seems to work the best.
http://members.***.net/1995z28/PROPERROUTEidk.jpg
Also, one of my wires is torn, not badly enough to see an actual wire. Can this still cause problems? These are new and I dont want to replace them again. I have heard of users using electrical tape to repair them. Would that keep the negative effects from happening?
http://members.***.net/1995z28/TORNWIRE.jpg
Re: Two plug wire questions: Routing and salvaging
[url]http://members.***.net/1995z28/PROPERROUTEidk.jpg[/url
Someone correct me if I'm wrong but electricity takes the path of least resistance(as do most things in life
) and since I'm pretty sure the resistance of electrical tape is far less than plug wire insulation., I would think you would still run the chance of losing spark and arching against something metal.. I, personally, would just replace them. Besides, if that electrical tape gets near anything hot it'll melt and smell bad
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
grabbem88
Mar 18, 2015 01:25 PM
