Opti-crap problems?
Opti-crap problems?
I own a 94 5.7l z28. 156.000 miles. I have replaced: coil, ignition module, plugs, plug wires, fuel filter. I recently have had sputtering, poping, backfiring, and power loss. Can barely get it up to 55 mph. I figured it was my distributor so i took out my radiator, shroud, water pump and hormonic balancer pulley. I removed the distributor cap to find the metal on the rotary button ( the part futherest toward the edge) very wobbly. It wiggles so much while spinning that it left marks inside the cap. But here is my question. When i install the new distributor( im buying a whole new one) how will i set my timing? And aslo right before i removed the pump or anything it stopped cranking completely. And is there any suggestions on what distributor to go with?
Prominent Member
Re: Opti-crap problems?
Are you referring to the rotor? Was that part loose in some way. How about the two screws fastening it down? They tend to come loose a lot. I would hesitate to but a new distributor unless you are sure it's defective and you get a top end one. Most of the Optispark distributors on the market are way worse than the original. Perhaps you just need a new rotor and cap.
There is no timing adjustment. Just be careful to get the shaft back in without forcing it out of keyed position.
Only 156,000 miles out of the original (???) distributor. Just don't make 'em like they used to. Sounds like the metal contact on the tip of the rotor came loose. Hard to understand how the qualifies it as "Opti-crap"
My recommendation would be full replacement with an AC Delco unit. As Gary points out, all you need to do is insure you correctly align the odd tooth on the splined drive shaft to the matching notch in the hole in the cam sprocket. Shoebox has a great alignment photo at shbox.com
The rotor is self is not loose. The metal on top of the rotor that spins was very wobbly and loose from the plastic. I took the distributor completely apart and found rust within it in a few different places. How do you feel about MSD?
I will be replacing the whole unit though. While driving the car to where i was going to work on it i heard a metal vibrating sound coming from the motor. Could my knock sensor also be bad? And could it also retard my timing?
How hard is it to turn the rotor? Could be failure of the friction bearing in the base of the Opti causing noise.
Then you don't have codes. There are no codes for misfires or problems on the high voltage side of the ignition in OBD-I. Transmission codes in general, do not turn on the SES light. There is DTC 16 for failure of the Opti's optical cam position sensor low resolution signal. Does not turn on the SES light. But if the code is active, the engine will not run because the PCM shuts down the fuel system.
And to explain the rotor problem further. There are two little white tabs that hold the rotor metal down. The outside one has broke of allowing the wobble. It also looks chared black due to bad conection.
Also me being a stupid 18 y/o. I disconected my exaust from the back of my cat to see if it was clogged. Come to find out someone already gutted it. I cranked it and liked the sound. I figured since it does not have a o2 on the cat i left it disconected. Could that have burned a valve? Or bent a rod? Or caused any major issues?
I have a dissected Opti sitting under my desk at work.
The metal strip on the rotor take the 20,000V spark from the coil, via the button in the center of the cap, and directs it to the buttons on the periphery of the cap that connect to the 8 spark plug wires. It takes a beating in 150,000+ miles.
This is the Shoebox photo that shows you how to index the splined driveshaft:
http://shbox.com/1/93-94_opti.jpg
You can't upload photos directly to post. You either have to have the photo saved somewhere on the internet, and post the address... or you need to upload photos to your CamaroZ28.com "pictures & albums" and embed the address of those photos in your post.
https://www.camaroz28.com/forums/sit...28-com-699204/
Magenta_Hearts
Mar 25, 2015 10:24 AM
