Ticking/Knocking noise from passenger side of engine
Old Oct 5, 2005 | 02:53 PM
  #46
robertotrevino's Avatar
Re: Ticking/Knocking noise from passenger side of engine
yeah, it's not that bad, but what if it gets worse? I prefer to prevent something mayor happening.
Old Oct 5, 2005 | 08:41 PM
  #47
MyShibbyZ28's Avatar
Mine has been getting progressively worse over the last couple months. First i thought it was the belt making the noise, then it got louder and i knew it wasn't that. Now it makes the noise when i've cruising at 30 mph. really starting to scare me. I don't want to be driving then have my engine fall apart. Mine is way worse then what is in the sound clip. This is loud enough that people next to me on the road can hear it.
Old Oct 5, 2005 | 10:00 PM
  #48
Mine is too, but the car wasnt that warm when I shot the vid.
Old Oct 8, 2005 | 02:35 AM
  #49
did you guys fix the problem?
Old Oct 8, 2005 | 02:00 PM
  #50
Tex95Z's Avatar
Kinda sounds like a main bearing
Old Oct 8, 2005 | 02:09 PM
  #51
main bearing, where's that? crankshaft, camshaft? I'm stupid when it comes to technical terms.
Old Oct 8, 2005 | 05:21 PM
  #52
PurpleStangEater's Avatar
Main bearings go between the crankshaft and the main caps
Old Oct 8, 2005 | 05:37 PM
  #53
radik's Avatar
Real loose roller rocker, or a main.
Old Oct 8, 2005 | 09:46 PM
  #54
Found out what it is. It's none of that, it's my exhaust. I couldn't move it by hand so i didn't suspect that for a while, but now i pushed on it with my foot and when i push it away from the frame, it stops rattling. I'm really releaved it's nothing internally with the engine.
Old Oct 10, 2005 | 12:36 AM
  #55
So how come you could only hear it from the passenger side and when the car was warm? where exactly was it hitting? I gotta try to fix it.
Old Oct 10, 2005 | 07:49 PM
  #56
It's not exactly the cat. It's the y-pipe and it's the portion that goes behind the rack and pinion from the drivers side. That's what's hitting on mine. If i take a screw driver and pry it away from the front of the car it'll stop.
Old Oct 11, 2005 | 11:22 AM
  #57
I finnally found the source!
Pic
Vid
In the video you can see how this piece moves with the sound.
The sound is definitely coming from there.. I believe its the thing that pulls the belt for it to be nice and tight. I dont really know the technical term.
Any ideas on how to fix it?
Old Oct 11, 2005 | 12:09 PM
  #58
Birdman7389's Avatar
Pic
Vid
Thats the tensioner. You could take it apart and regrease it, or just pick up a new one...
Old Oct 11, 2005 | 12:13 PM
  #59
Is it difficult to fix? or could I do it on my own?
Old Oct 11, 2005 | 12:38 PM
  #60
That sounds very similar to mine but mine is louder and more rapid. Plus when I pry the y-pipe away from the front of the car, the noise gets weaker or quiter and somewhat goes away. I'll check it out and see.
blown94
May 3, 2015 12:48 AM
Chris Anderson
Jan 27, 2015 08:30 AM
Jul 4, 2005 05:00 PM
Bando
Oct 7, 2002 07:36 PM
blue89iroc
Jul 26, 2002 04:56 PM
