what pushrods? what gaskets?
Old Oct 10, 2005 | 10:12 PM
fade2blk500's Avatar
Put in a gm847 cam, crane double springs, and crane gold roller rockers. need to get some pushrods that will hold up to the high lift/duration. Which do you recommend? I read that a 7.200" should be used but I searched and couldn't find a part #.
Also, I looked at the parts store and I got the timing cover gasket set but it didn't have the smaller opti/water pump seal that goes into the timing cover. I went back to advanced and tried to look it up but couldn't find it. If anyone has the part # that would be awesome!
Thanks!
Craig
Old Oct 11, 2005 | 02:25 AM
jkipp84's Avatar
Re: what pushrods? what gaskets?
I used comp hardened push rods with my XE 224/230 and non-self aligning 1.6 pro mags. I got them from Thunder, I think they're around $35ish.
For the timing set is this the one you're talking about: TCS45956
Old Oct 11, 2005 | 05:29 AM
thanks!
Old Oct 11, 2005 | 06:00 AM
cehan's Avatar
You really need to check your pushrod length using an adjustable pushrod tool and a couple ofchecking springs to be sure that you get the correct length. For example the correct length for my head/cam/spring package with Comp Pro Mags turned out to be 7.050"
Chris
Old Oct 11, 2005 | 08:11 AM
1racerdude's Avatar
Post Re: what pushrods? what gaskets?
Chris
Ditto
Proper length will make a big difference on the pushrods. No two engines are the same and ya need the GM guideplates with the hardened pushrods.
Shoeboxe's site should have all the info on part number's ya need.The seals are a dealer item.
Old Oct 11, 2005 | 09:22 AM
rskrause's Avatar
Moderator
Ditto what Chris said. A PR checker is an essential tool if you are going to start building engines. Look here for some info: http://www.compcams.com/Technical/Cu...ML/306-307.asp Comp #7905 is a checking PR with a range of 6.100-7.500" and costs <$15.
Rich
Old Oct 11, 2005 | 01:09 PM
well i'm using stock heads, stock lifters, and no guideplates. I have self aligning roller rockers. It should be fine with a standard 7.200" pushrod.
13qtr
Oct 28, 2016 08:11 PM
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
