Throttle body bypass
Old Feb 8, 2005 | 01:34 PM
  #61
blind527's Avatar
Re: Throttle body bypass
is there a problem with over heating after doing the throttle body bypass?? my engine is at about 240, normally runs at like 210? or is this just a glitch because i bypassed it? or heating up because the coolant dripping down?
Old Feb 8, 2005 | 02:49 PM
  #62
crazypurgatory's Avatar
Thats's strange it sould not run that hot.
you might have an air pocket in the engine.
I would turn on the AC so the coolant fan is on and take it for a long drive.
That should get rid of any air pocket's.
If it still runs hot then you have to try to bleed it out throught those bleed screws I told you about in my other post.
And a couple of heat up and cool down cycles should thake of the coolant level in the over flow and the Rad.
Chris.
Old Feb 8, 2005 | 02:53 PM
  #63
CamaroUK's Avatar
You can syphon the excess out of the reservoir with a bit of tubing.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
warmeck
May 1, 2015 11:30 AM
RedLineRev
Jan 23, 2003 03:51 PM
