Throttle body bypass
Old Feb 1, 2005 | 06:47 PM
JAG05's Avatar
I did a search and i still couldn't find a site... but does anyone know a site that will tell me and have pictures on how to make my own throttle body bypass??
Old Feb 1, 2005 | 06:53 PM
DiabloGT's Avatar
Re: Throttle body bypass
i heard you can do it for free on a 95+ does anyone have any info/site on this? and how to do it
Old Feb 1, 2005 | 07:21 PM
JAG05's Avatar
Another questions. I know they did that to keep the throttle body warm in cold weather. Has anyone had any problems like the throttle body freezing?
Old Feb 1, 2005 | 08:30 PM
crazypurgatory's Avatar
Here the Shoe can help you out.
Just check out his page.
He has pictures of it.
http://shbox.com/page/index.html
Good luck,
Chris.
Old Feb 1, 2005 | 08:40 PM
JAG05's Avatar
He has it for a 95-97 car. Mines a 94. Its different...
Old Feb 1, 2005 | 08:49 PM
TransAm2k4's Avatar
I have a 94 and all i had to do was Remove the lines that connect under the TB and then plug does line together but make sure that water can still run throu there. Then if you want plug the TB openings from where you removed the lines. try this site. www.projecttransam.com they have lots of usefull info.
Old Feb 1, 2005 | 09:02 PM
1997Z's Avatar
This is probably a stupid question, but what is the point of doing this? What is gained?
Old Feb 1, 2005 | 09:08 PM
TransAm2k4's Avatar
Cooler intake Air = More HP. I can't tell the Diff because i did it at the same time as HEads and Cam
Old Feb 1, 2005 | 09:10 PM
1997Z's Avatar
Which AFR heads did you use?
Old Feb 1, 2005 | 10:42 PM
MentalCaseOne's Avatar
What is the point of doing that? My car used to run good when cold.. as soon as it was fully warmed up there was a noticeable drop in power.
After my TB bypass the car has ran as strong as it did when it was cold. So what it does is that it keeps the air from getting hot and reducing the air density reaching the cylinders and robing the engine from oxygen and power while fully warmed up....
There isnt any gain in horsepower per say.... in my opinion in only keeps you from loosing your "cold engine horsepower" feel.... at the tone of about 7 hp... I like the TB bypass.. car feels always the same.... cold or warm... nice mod and it was free for me.
Marvin
Old Feb 1, 2005 | 11:23 PM
brians96Z's Avatar
So there is no negative side effects of bypassing the TB then?
Old Feb 2, 2005 | 04:35 AM
I havent had any negative side effects that I can say... yeah it was the throttle bypass.... its working fine.
I wonder about those guys who live in very cold climates though..
Marvin
Old Feb 7, 2005 | 01:56 PM
blind527's Avatar
i'm kinda nervous about doing this throttle body bypass....is it easy??? i see it says something about vaccuum clamps 3/8"...i don't have any of those. i have a 97 formula, and i will be getting a cai and 160* thermostat within a few weeks.
it seems kind of confusing, what to do with the clamps and everything...
Old Feb 7, 2005 | 02:02 PM
Black_95Formula's Avatar
The TB bypass is one of the easiest free mods for the LT1. If you search you will find a ton of dyno sheets, some with over 10RWHP gains after the bypass.
If you picture your TB, it has 2 colland tubes coming out of it. The way to tell is when the car is running, touch the black tubes to find out which ones are hot from the coolant. They are about 1/2 inch in diameter.
With the car off, unplug those 2 tubes (make sure to have a towel underneath) and then connect them to each other using a connector found at any automotive store with a set of clips to hold em on. Done.
Old Feb 7, 2005 | 02:06 PM
blind527's Avatar
on mine it says take the rubber hose that was connected to the returns side of the TB and connect it to the metal tube comming up from the back of the head on the feed passangers side. clamp it, use one of the existing spring clamps that are no longer needed.
it also says remove both spring clamps from the passangers side feed line on the TB and on the steel line comming from the back of the head.
that seems a little confusing to me, cause it says no where that i need a connector..
