Are these o2 sensor bungs (header pic)---
Old Nov 3, 2006 | 10:11 AM
AlwaysCode390's Avatar
Smile Are these o2 sensor bungs (header pic)---
I am about to buy a set of headers from a guy and wasnt positive these are the o2 sensor plug-ins or if these are the emissions plug-ins. I want the offroad type, thanks ---
These are 3 peices, so they are the JET HOTs and not the HOOKER style right? ---
Old Nov 3, 2006 | 10:35 AM
Ricardo's Avatar
That is the connection for the air pump.
RG
Old Nov 3, 2006 | 10:38 AM
Sweetred95ta's Avatar
That's an emission hook up. You can just cap it off and be fine.
2000GTP's Avatar
Yeah, that is the air pump fitting so I think that would eliminate them as being the "off-road" version.
Old Nov 3, 2006 | 10:45 AM
O2 sensor connections would be located on the header collectors, not on the primary tubes. If the headers have three connections on the primaries, 2 are for the AIR connections, and one is for the EGR riser tube.
Old Nov 3, 2006 | 10:59 AM
OK, thanks guys.....can both AIR and the EGR tube be capped off easily and not affect performance? I really appreciate the help ---
Does anyone know if these are the Jet Hot brand or JH Coated Hookers? Is the performance comparable to the pacesetters? ---
Old Nov 3, 2006 | 11:22 AM
2000GTP's Avatar
Yes you can cap off the emissions fittings. The loss of the air pump will have zero affect on the car and the removal of the EGR should not affect it either, but still questionable. Seeing that you have a 96, you will have to have your PCM tuned so you don't set an SES light. The performance of those headers will be similar to that of the Pacesetters.
Old Nov 3, 2006 | 11:42 AM
Great, thanks alot....I had to get the egr tuned out of the pcm to pass emissions a week ago, so this will work great!!! True duals here I come ---
DirtyDaveW
Mar 15, 2015 07:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
PaulN64
Aug 8, 2002 05:39 AM
