There may be a new lifter option
Old Feb 10, 2007 | 06:19 AM
  #31
quickSS's Avatar
Bret showed these lifters to me when visiting the GM island at PRI last December and I've had them circled in the GMPP catalog and finally purchased a set from Dal (support DAL whenever possible).
Found in the Chevy LS Series section of the GMPP catalog #88958789
Just left of the LS7 Titanium connecting rod at $2736 for a set of 8. Wa!!.
Racing Hydraulic Roller Lifter Kit:
As developed by GM Racing and GM Powertrain
For use in Gen III and Gen IV engines where sustained high rpm's are typical
Special reduced-mass internal components allow for higher limiting speeds with aggressive camshaft designs
Improved valvetrain dynamics and stability will improve horsepower, and high rpm's
Tested to 8000rpm in GM racing applications
Set of 16.
I'm going to give them a try in a stock bottom tree-fiddy later in the spring.
Karl
Old Feb 10, 2007 | 09:33 AM
  #32
AdioSS's Avatar
West South Central Moderator
so, these are LS7 lifters basically? It makes sense because that thing revs to 7000 easily
Old Feb 10, 2007 | 10:45 AM
  #33
AdioSS's Avatar
Originally Posted by quickSS
...finally purchased a set from Dal (support DAL whenever possible).
Karl, what was the price through Dal?
Cheston
Old Feb 10, 2007 | 01:58 PM
  #34
12SCNDZ's Avatar
$241 at my local Chevy dealer, with my wholesale discount.
Frank
Old Feb 10, 2007 | 03:22 PM
  #35
madhatter's Avatar
Well the real question is which is better, these or LS7 lifters?
Old Feb 10, 2007 | 03:24 PM
  #36
quickSS's Avatar
Cheston
$240 somethin' from DAL to Door.
Karl
Old Feb 10, 2007 | 06:42 PM
  #37
SStrokerAce's Avatar
THESE are better and they are not LS7 lifters. I just wish they were tie bar lifters like the Morel's too.
Bret
Old Feb 10, 2007 | 08:29 PM
  #38
Fastbird93's Avatar
Bret
What's the reasoning behind that?? Less chance of one turning with the Morels, or am I missing something bigger?
Old Feb 10, 2007 | 08:55 PM
  #39
Kevin Blown 95 TA's Avatar
I thinks thats what he was getting at.
Old Feb 10, 2007 | 09:18 PM
  #40
cdb95z28's Avatar
Any concerns with the type of retaining clip for the internals, especially with minimal preload?
Old Feb 10, 2007 | 09:19 PM
  #41
No if GM made them they work fine.
Yes the bars make sure you never spin a lifter.
Bret
Old Feb 10, 2007 | 10:07 PM
  #42
quicksilver97ta's Avatar
subscribing.
Old Feb 11, 2007 | 01:24 AM
  #43
maro z28's Avatar
Could you just get a rev kit...then again you'd be at the price of Morels, but theoretically you'd be doing just about the same thing, right??
Old Feb 11, 2007 | 01:28 AM
  #44
Z-RATED94's Avatar
Do a search, and maybe you'll forget about the rev kit.
Old Feb 11, 2007 | 01:34 AM
  #45
maro z28's Avatar
Already been there...I'm just talking in theory.
