There may be a new lifter option
Old Feb 9, 2007 | 12:32 PM
  #16
seawolf06's Avatar
What preload did you set?
Old Feb 9, 2007 | 12:37 PM
  #17
97WS6SCharged's Avatar
PN 88958689
http://www.sdpc2000.com/catalog/4674...es-Engines.htm
Old Feb 9, 2007 | 12:49 PM
  #18
roadtrip120's Avatar
Just ordered a set from SDPC today, for a 383 Le2
pt sd8689 217.85 /set
Ls7 Lifter preload according to ls1tech, 1 to 1-1/2 turns.
crane did some testing and found that .060" of preload (cold) is best for hp, using (there) lifter. Thats around 1-1/2 turns.. They claim they made 20hp more than using the standard 0.010" (cold)preload setting..
not sure if that applies to these lifters or not
Old Feb 9, 2007 | 01:08 PM
  #19
seawolf06's Avatar
.060" is 1 1/5 turn on 7/16" studs and 1 1/2 turns on 3/8" studs, just in case anyone was wondering.
I'm guessing this would be better since it can keep more pressure on the lobes without losing compression or lift. Any more comments about what applications would require these and how to set them up, Bret?
Old Feb 9, 2007 | 01:09 PM
  #20
trans9_5am's Avatar
subscribed
  #21
SStrokerAce's Avatar
Don't follow that preload.... it's almost always better with less. Crane maybe one case but I would say that every set of lifters I have dynoed did better with less preload.
Bret
Old Feb 9, 2007 | 01:33 PM
  #22
Fastbird93's Avatar
Wow, I'm glad to see the reception to these. I wasn't sure if I was off my rocker or not when I posted this because I thought someone has got to know about them and mentioned it here.
Whoever had it, thanks for the part number. I was just getting ready to find it.
Mainly, I'm just glad that there's a less expensive but quality alternative now.
Old Feb 9, 2007 | 02:15 PM
  #23
speed_demon24's Avatar
Not true, .060 is about 3/4 turn on a 7/16 stud, it would be 1 1/5 if thepushrod was right under the polylock but it isn't. And I would follow what bret says about the preload. Just out of curiosity, why do they make more power with less preload? I always wondered that but can't find an answer anywhere.
Old Feb 9, 2007 | 02:17 PM
  #24
This should make a bunch of people happy. Nice to see a thread with some seemingly good news in it.
Old Feb 9, 2007 | 02:20 PM
  #25
mdacton's Avatar
Yes sirr, good info
Old Feb 9, 2007 | 02:28 PM
  #26
Z-RATED94's Avatar
OK, where was this info 7 months ago guys? When I was swapping out the new style Comp-Rs. Holding out on us huh? That's not nice.
Old Feb 9, 2007 | 02:39 PM
  #27
seawolf06's Avatar
SDPC only got them 5 months ago...
Old Feb 9, 2007 | 03:27 PM
  #28
SS1156's Avatar
Sweet deal......I need some of these for my cc306 install
Old Feb 9, 2007 | 10:37 PM
  #29
12SCNDZ's Avatar
OK..I'm trying to figure all this out. I always adjust my valves with the motor running. When I did my CC305 cam with COMP "stock replacement" lifters, I went 1/4 turn past "chatter". Wouldn't 1 turn past zero equal 1 turn past "chatter" with the engine running?
Frank
Old Feb 9, 2007 | 11:33 PM
  #30
Frank
At the point where chatter just stops, that should be effectively zero lash.
