TDC qustion
Old Feb 17, 2008 | 03:30 PM
Pontiac_97's Avatar
TDC qustion
Ok my actual hub shifted. i dont know how but it did. im wondering once the intake valve closes how much more do i have to turn the crank for #1 piston to be TDC?
Old Feb 17, 2008 | 04:34 PM
The hub can shift because its not keyed to the crank. You can't really rely on it to locate TDC. A "whistler" in the plug hole, or a non-metallic probe in the plug hole wiil give you a better indication of TDC than rotating it "x" degrees after the intake valve closes. Alternatively, get it close to TDC, drop a valve on the top of the piston, and put a dial indicator on the valve stem.
Old Feb 18, 2008 | 07:18 AM
Pontiac_97's Avatar
whats a whistler? is the spark plug directly on top of the piston or is it on the side of it? if i stick a straw in the plug hole will i see it rise out or move when the piston comes up?
9t4lt4z28
Oct 2, 2015 10:28 AM
grendal
Jun 30, 2003 11:59 AM
95_RipperZ
Jun 28, 2003 12:25 PM
joefreeland
Jun 22, 2003 09:25 PM
RedZ-28
Jun 5, 2003 01:39 PM
