finding tdc and water pump shaft seal
Old Jun 22, 2003 | 08:47 PM
joefreeland's Avatar
I aligned the dots on the timing set and it looks Like 6 is on tdc. If i rotated the crank 180 degrees. will #1 be at tdc? I wanted to know cause i didnt mark my crank hub when i pulled it. When i get 1 at tdc all i need to do is install the hub with the arrow up is this correct. also im not sure if i have the water pump seal installed right. It doesnt seem like its far enough in or the shaft isnt far enough out. I can send someone a pic too look at it.
If anyone ever needs help with an install in my area email me and I will try to help. It sucks trying to do it alone.
thanks
Brad
Old Jun 22, 2003 | 09:25 PM
Just put your hub on with it at #6 (dots lined up). It will be perfect. You would have to rotate it 360º for it to be at #1 and it won't make a hill of beans as far as the hub goes. You would still put it on with the mark at 12 o'clock.
W/P seal
HectorM52
Jul 30, 2017 11:46 AM
grgguy
17
Feb 23, 2015 07:57 PM
Jazsun
Dec 29, 2014 12:14 PM
pologreen97z
Dec 2, 2014 10:42 AM
