TDC question
Old Jun 28, 2003 | 11:09 AM
95_RipperZ's Avatar
TDC question
I am changing my valve springs. When the #1 cylinder is at TDC, what other cylinders are at TDC? Then, how much do I need to turn the crank to get the other cylinders to TDC. Anyone have an order for me to follow while changing these?
Old Jun 28, 2003 | 11:27 AM
jkipp84's Avatar
Cool
Once again - Shoebox to the rescue: here you go
Old Jun 28, 2003 | 11:45 AM
95_RipperZ's Avatar
That helps some. Here is what I am thinking I should use. All I am tryig to accomplish is not having the valves fall into the engine. So ccording to this firing order, does that mean I can change the #1 AND the #6 valve springs at the same time? Or is it that only 1 cylinder at a time is at TDC?
"If you want to set the lash by bringing each cylinder to TDC, watch the valves and the pointer on the balancer and follow the Firing order:
1-8-4-3
6-5-7-2
Adjust both intake and exhaust of the cylinder that is at TDC. You will have to make 2 revolutions of the crank, stopping at 1/4 (90º) turn intervals for each cylinder."
Old Jun 28, 2003 | 11:49 AM
95_RipperZ's Avatar
Ok, so this is what I have come up with so far. Am I right?
TDC #1- change those valve springs, then turn the crank 90 degrees and change #8, then #4, then #3, etc.
If that is right let me know, then I can get started.
Old Jun 28, 2003 | 11:53 AM
jkipp84's Avatar
I believe I'd follow that one too.
I've never done springs with the heads on the car though. You may want to feed in some rope through the plug hole to help keep the valves all the way up.
Old Jun 28, 2003 | 12:25 PM
95_RipperZ's Avatar
ya, i would do that to make sure each is at TDC but Im lazy. If it is just a hair off of TDC , they wont fall in. I finished teh #1 but need to move on. So I am just going to follow the firing order. Wish me luck.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
smokin5s
Jul 24, 2003 10:47 PM
