Is my timing gear upside down?! HELP!
Old Jun 29, 2003 | 11:56 PM
grendal's Avatar
Hi guys...
Summary: I'm finishing a cam install, adjusting valves stage.... timing cover is OFF....
With the dots LINED UP, my car is NOT at #1 TDC! With the dots LINED UP on my stock timing set w/ a HOTCAM, I am at #6 TDC, NOT #1 TDC! #1 TDC occurs with both dots facing straight up (i.e. where it should be #6 TDC).
WTF is going on?!.... I cannot possibly see how I could do this wrong. I lined up the dots, pulled out the cam, put in the new cam, lined the dots back up (did not move crank).
HELP! I'm so confused. I adjusted the valves, but I haven't a clue why mine don't line up right.
-Michael
Old Jun 30, 2003 | 12:13 AM
With the dots together it is supposed to be at #6 TDC. You are fine. Both dots at 12 is #1 TDC.
Old Jun 30, 2003 | 12:21 AM
grendal's Avatar
Shoebox,
THANKYOU THANKYOU! So why is this differentiated from a Gen1 SBC? Isn't lined-up usually #1 TDC?
What about on an aftermarket timing set?
Thanks,
Michael
Old Jun 30, 2003 | 11:59 AM
Originally posted by grendal
Shoebox,
Thanks,
Michael
I think they are all the same from what I remember about the old SBCs. It just depends on how the cam is indexed to the gear.
ChrisFrez
Dec 15, 2014 03:09 PM
Noenav
Dec 6, 2014 07:35 PM
1LEThumper
Jul 14, 2003 12:45 PM
