Street cam with torque(full precise details)
Old Jul 29, 2007 | 01:41 PM
  #466
SS RRR's Avatar
Originally Posted by speed_demon24
Well my valve springs were toast after 4k miles (lost 14-28lbs), but I'm not a valvetrain expert so I can't say if that was from the cam, cracked guides, or some other variable.
Bret can... even w/out seeing the heads he knows!
Old Jul 29, 2007 | 01:42 PM
  #467
96LT1TX's Avatar
I have read every pathetic page of this and I am not picking sides. I am from Plano and will be back sometime this next semester, look forward to it. I am finally getting slicks so I will video it just for you. I have seen a bunch of people post times I dont feel like searching on sunday for LE times... not my cup of tea.
I built my bottom end so it will be the first test of how good I did!! haha only 650 miles on new motor
Old Jul 29, 2007 | 01:43 PM
  #468
dangalla's Avatar
i believe what he said was that due to the cracked guides allowing the springs to "dance" around in the head that very well could have been the cause of the the marks on the valves from the keepers
but i def am no expert on this subject i am only posting what i read
edit:
Originally Posted by SStrokerAce
when the valve is not controlled by the guide laterally lots of odd things can happen to make the valve dance around with the spring and retainer.... now the 918's could have been at fault if they were the 2006+ examples from Comp, but it's hard to say what happened here with all the unintended valve movement caused by the guide.
Old Jul 29, 2007 | 01:45 PM
  #469
Z-RATED94's Avatar
Just... wow... before you pick an accusation and blindly rampage through it pehaps you should do a little research?
<----- low altitude looser
You will post anything no matter how stupid it makes you look just as long as you think it betters your failing cause.
There you go with the faces again. Is that some sort of nervous twitch? When I try it doesn't quit give me the pleasure it does you. What am I doing wrong?
Old Jul 29, 2007 | 01:50 PM
  #470
SS RRR's Avatar
I agree wholeheartedly. You've got your threads mixed up now, son.
I see you conveniently left out the first part of that "FWIW it wasn't valve float...." sentence.
THAT'S what I was questioning.
So at first you were challenging my motive and you've been widdled all the way down to these type of simplistic, mindless responses. As already said your cause has failed and it shows.
Thanks for playing.
Old Jul 29, 2007 | 01:54 PM
  #471
dangalla's Avatar
i understand what you were questioning, i meerly posted the reasoning behind what he said, like i said i am no expert on this subject
Old Jul 29, 2007 | 01:55 PM
  #472
SS RRR's Avatar
I UNDERSTAND the reasoning. It's the very first sentence that I was questioning. The very first sentence was a lead off to the reasoning. Do you understand?
Old Jul 29, 2007 | 02:48 PM
  #473
SS MPSTR's Avatar
and what exactly are you contributing......nothing
i would just like to hear some examples of unhappy customers, so post em, with all the hate you have for him you surely must know of some unhappy customers
I've been asking the same simple question for months now. I thought that was one of the purposes of this forum?
No hate for senior or junior stroker - like I've been stating, there are still no answers to the questions and seeking out unhappy customers doesn't mean a damn thing..
Old Jul 29, 2007 | 02:59 PM
  #474
SS MPSTR's Avatar
what cam did you have again? did you ever put it on a cam doctor or cross-reference the lobes to see what you really had? springs failing @ 4k miles seems to be a huge red flag.
Old Jul 29, 2007 | 03:03 PM
  #475
dangalla's Avatar
true and all i did was turn the tables and ask you one simple question, and just like you believe you deserve an answer(and believe it or not i also think you should get your answer) i believe i deserve an answer
so please, go ahead and post up some good examples of unhappy customers, if for nothing else but to prove your own point to all the people reading this thread and trying to decide weather or not to buy a cam from him.
if you seriously cant post up some examples then all your doing is making him look good, do you not realize that
  #476
Zigroid's Avatar
FOUND ONE!
Or is ignorance bliss?
lol I skimmed over the last 2 pages but im assuming you guys are talking about my car being the stroker that trapped 112? ever stop to think that I just had problems with parts not related to lloyd and bret?
did you know I had 4 failed comp R lifters? I found 3 retainer clips, don't know where the 4th one went. this was after I had the lash set perfect and checked many times.
did you know I had no tuning? seems no one around here can tune LT1s, or at least that I could find.
did you know I had a terrible vacuum leak that I could not find? I had 6" of idle vacuum and it wasnt because of the cam. I degreed the cam twice, everything checked out.
did you know the used short block I purchased (and stupidly never checked the bearings out) had the incorrect pistons which dropped my compression ratio to around 10.5:1? my DCR was in the mid 7s...
did you know my car was a heavy pig? fully optioned, heavy torque thrust IIs all around, spare/jack/backseats all in place, and with my heavy 250 lbs in it. I bet the raceweight was around 3800 lbs. there was nothing light about that car.
did you know I was on the completely stock 130,000 mile suspension? my rear end was even shot, I peglegged bad.
did you know I race at a track known for its ****ty prep and track times? everyone I know runs 2-3 mph slower there than at other tracks. it was also 90+ degrees and very humid. I have a friend with a 440 rwhp all motor TA that runs 12.5 @ 115 at the same track in the same weather that I ran my 12.7 @ 113. thats AFR heads and a TTP equalizer v3 cam, all installed and tuned by TTP in NJ. a "reputable" shop I guess. countless bolt on cobras are running mid 12s. stock LS1 cars run mid 13s. stock/light bolton LT1 cars run mid 14s. 05 goat running high 13s.
but you guys just see "blah blah blah" excuses excuses because youre just out to destroy bret and lloyd...
I can prove I wouldve gotten faster as I worked bugs out...
my first time out with my LE3 383 I ran mid 13s @ 103. it was pulling 8-12 degrees of knock retard, had crappy mac headers that leaked before the O2 sensor (one bank was running excessively rich.) I kept fixing things and knocking my ET down.
went from a mid 13 @ 103 to a low 13 @ 105 just by fixing my MAP sensor.
wired a resistor in line to eliminate the false knock. that dropped me to a 12.6 @ 109 with drag radials. that was with a torque converter whose lockup clutch failed not 400 miles later that destroyed my freshly built transmission.
I had the converter and the trans rebuilt, replaced the mac mids with pacesetter LTs and replaced my drag radials with sumitomo street tires.
my ET went up to a 12.7 since I had uncontrollable wheelspin but my mph jumped to 113. I was still having issues with the tune and electrical bugs/vacuum leaks that I couldnt figure out. a week after I ran the times I spun a rod bearing and cracked two main caps. being a relatively poor college student and tired of pouring money into my car I decided to stick the stock engine back in it and cut my losses. I really wish I couldve kept at it and pushed her into the 11s but I just didnt have the patience or the budget to do show. I am certain that with the correct pistons, a fresh short block, lifters that actually did their job, a tad more weight reduction, and good tires.
regardless of how poor my car performed at the track I still ran pretty well on the street. like I said, I was even with a 400 whp 50 trim AGP kit'd SRT-4, beat a 350 rwhp bolt on TA by buslengths, only lost by a few cars when he sprayed a 150 shot, and I destroyed a 370 awhp evo along with a bunch of other lesser cars.
man all this talk sure does make me miss the car despite all the problems I had. come to think of it I think the ONLY parts that didnt give me problems were the parts supplied by lloyd and bret. I had problems with my throttle body, lifters, bottom end, and electrical/tuning. nothing with the heads, the cam, or the intake.
edit: spaced things out a bit so it was easier to read
Old Jul 29, 2007 | 03:07 PM
  #477
dangalla's Avatar
haha and this was your unhappy customer
Old Jul 29, 2007 | 03:09 PM
  #478
speed_demon24's Avatar
I cross referenced the .006 and .050 durations along with the lift and found the intake lobe in the catalog but I can't find anything that matches the exhaust lobe. The cam is a custom cam from bret that I bought a couple months before I sent my heads to Lloyd.
Old Jul 29, 2007 | 03:16 PM
  #479
SS MPSTR's Avatar
wow...longest post of excuses ever. sorry your car never ran right.
Old Jul 29, 2007 | 03:20 PM
  #480
SS MPSTR's Avatar
I'm confident that most people reading this charade recognize the difference between 'customer service' and 'credentials'. Posting unhappy customers doesn't prove my contention, nor does not posting in response to your demands disprove it.
