step by step opti replacement?
Old Jan 8, 2004 | 11:53 AM
  #16
Tires_Smokin's Avatar
Originally posted by Don 97 SS
Shoebox, would you happen to know the p/n for the 95-97 distr drive shaft seal?
BTW, I agree, it is really easy (as I've done it all too frequently) to remove the entire fan housing. Just unhook both fans' wiring harness from the motor connectors and lift and drop the entire housing from the "fingers" that hold the housing against the rad.
I think it's part #12552428 from gm parts direct $3.68
**Anyone know what part number the EGR tube is that goes to the header?
THANKS
PEPPER
Old Jan 8, 2004 | 11:56 AM
  #17
xxsaint69x's Avatar
i will second that it can be done in 45 min....ITS REALLY EAZY. I have no idea why you would want to remove the fans
Old Jan 8, 2004 | 12:13 PM
  #18
THANKS
PEPPER
That is the correct p/n for the 1995-1997 front cover opti seal.
EGR stuff
DirtyDaveW
Dec 1, 2016 05:37 PM
grabbem88
Mar 18, 2015 01:25 PM
Sandersen511
Jan 13, 2015 03:49 PM
pologreen97z
Dec 2, 2014 10:42 AM
