starting troubles
Old Oct 30, 2011 | 09:32 AM
Like My Taillights?'s Avatar
starting troubles
My car has been sitting for about a year now and won't start. Yesterday i charged the battery and put it in, but when i turn the key the starter just makes a grinding sound. So i figure the gear on the starter isn't sliding onto the flywheel? The flywheel has a tooth missing? Engine is seized? This problem never happened before, so I'm wondering what could have caused this problem? The sad thing is that this car hasn't seen snow in ten years and now it has a foot of the white stuff on it. Any suggestions on how to get car running would be greatly appreciated. Thanks-Rob
Old Oct 30, 2011 | 09:52 AM
Re: starting troubles
Might want to try a new battery.
Old Oct 30, 2011 | 01:52 PM
Just bought and installed a new battery. No luck. The starter is still grinding.
Old Oct 30, 2011 | 02:43 PM
Did you check the main cables for corrosion on the battery end, and on the starter end?
DirtyDaveW
Dec 1, 2016 05:37 PM
armedtrigger
Feb 24, 2015 08:30 PM
warmeck
Feb 2, 2015 12:44 AM
David Dorris
Jan 17, 2015 08:10 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
