Shift light
Old Aug 10, 2003 | 06:21 PM
Lyle A's Avatar
Shift light
Is there a Shift light out there that I can install without buying a tach also? I would like to put a light in the dash and keep the stock tach.
Old Aug 10, 2003 | 06:35 PM
atljar's Avatar
harlan-engineering.com But expect it to take FOREVER for it to get delivered.
Also one called "raptor performance shift light" Do a search on google for that link.
Old Aug 10, 2003 | 06:40 PM
Lyle A's Avatar
Thanks, Is there any others or is that it?
Old Aug 10, 2003 | 06:55 PM
atljar's Avatar
Those are the only 2 that i know of that can be run straight from the coil and are fairly small.
Proform has one that can be run straight from coil, but its bigger.
Also, there are many other lights that will run off rpm pills plugged into a MSD box if you have one
Old Aug 10, 2003 | 07:13 PM
Lyle A's Avatar
Thanks, I just looked at the Raptor. I may go for that one.
Old Aug 10, 2003 | 07:21 PM
12SCNDZ's Avatar
I've got an Autometer shift lite mounted on the top of my dash. It's spliced right into the factory tach wires in the dash. I Still use my factory tach for most stuff, but I shift off the shift lite while racing. The Autometer is a great unit and has worked great for me. Mine was in my previous car ('77 Camaro) before this one, so I'd guess it's probably about 10 years old.
Frank
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
phantasm99
Aug 28, 2002 11:01 PM
Brady
Jul 29, 2002 10:30 PM
