Shift light
Those are the only 2 that i know of that can be run straight from the coil and are fairly small.
Proform has one that can be run straight from coil, but its bigger.
Also, there are many other lights that will run off rpm pills plugged into a MSD box if you have one
I've got an Autometer shift lite mounted on the top of my dash. It's spliced right into the factory tach wires in the dash. I Still use my factory tach for most stuff, but I shift off the shift lite while racing. The Autometer is a great unit and has worked great for me. Mine was in my previous car ('77 Camaro) before this one, so I'd guess it's probably about 10 years old.
Frank
Frank
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
phantasm99
Aug 28, 2002 11:01 PM
