Resetting PCM Codes
Old Mar 17, 2004 | 03:32 PM
Dan Oldham's Avatar
Resetting PCM Codes
I'm having some work on my transmission done and the guy doing it says that some codes are coming up on the PCM. What types of codes would come up on the PCM due to a transmission? It's got a 2400rpm stall, shift kit, beefed up clutches, and springs. The TC is a lock-up.
Also, he's trying to reset the codes, and for some reason the error codes are still present after the PCM has been re-flashed. He's got someone looking into it now.
Any ideas of what can cause this?
Old Mar 17, 2004 | 04:48 PM
A4 related codes on OBD-I:
58 - Transmission fluid temp circuit, voltage low, high temperature
59 - Transmission fluid temp circuit, voltage high, low temperature
72 - VSS loss
73 - Pressure control solenoid circuit, current error
74 - TCS circuit low
75 - Transmission system voltage low
79 - Transmission fluid overtemp
80 - Transmission component slipping
81 - Transmission 2-3 shift solenoid circuit
82 - Transmission 1-2 shift solenoid circuit
84 - (A4) Transmission 3-2 control solenoid circuit
85 - Transmission TCC stuck "on"
90 -Transmission TCC solenoid circuit
Old Mar 17, 2004 | 05:04 PM
Dan Oldham's Avatar
Thanks for the reply!
armedtrigger
Feb 24, 2015 08:30 PM
91Bird305
Aug 5, 2002 01:39 PM
tbyrne
Jul 2, 2002 05:37 PM
LT1der
Jun 23, 2002 10:06 PM
Z28AZ
Jun 14, 2002 04:16 PM
