Rear Main Seal install questions
Old Sep 27, 2020 | 03:28 PM
1994-LT1-Eric's Avatar
Hey all,
Does any oil or grease need to be used with this type of RMS during installation, and if so where do you apply it?
Also, can someone explain how that plastic insert/guide tool actually works? Is it needed? I was just going to use a rubber mallet and gently tap the seal in all the way around until it's flush. Is the plastic piece pulled out after you install?
Thanks,
Eric
Old Sep 27, 2020 | 03:39 PM
Re: JUST READ THE INSTRUCTIONS
Just like I tell my technicians when I disposition work to be done: "Read all the instructions."
Sigh...🙄
Old Sep 27, 2020 | 05:16 PM
Re: Rear Main Seal install questions
Think positive - At least if someone uses the “search” feature they'll find the right answer......
Old Sep 27, 2020 | 07:37 PM
DrewHMS97SS
Jan 1, 2020 10:18 PM
awill12
Oct 11, 2012 03:58 PM
DemonZ28LT1
May 11, 2005 09:51 AM
phil94-T/A
Pacific
Mar 11, 2004 12:27 AM
twells
Jun 10, 2003 09:13 PM
