New TEFLON Rear Main seal won't slide on!! HELP
Old May 11, 2005 | 09:39 AM
DemonZ28LT1's Avatar
I got a new TEFLON rear main seal and Im ready to install it. The gasket is in place and u don't put sealant on that right, well the rear main comes with a installer but the damn thing will not go on the car, I have the housing off and put the seal in the housing and trying to install but it wont go. Any suggestions and do I lube it up first?
Old May 11, 2005 | 09:42 AM
WS Sick's Avatar
Re: New TEFLON Rear Main seal won't slide on!! HELP
even with teflon you have to oil a seal and the surface good to get it on.
nathan96's Avatar
not sure, but I had them open the boxes for me to match up with the old one and the teflon one wasn't even close to matching. This was at autozone where they had two parts listed for the seal.
Old May 11, 2005 | 09:51 AM
COOL! WD40 did the trick. I got this at autozone and it's teflon, it seems smaller because it has the ridges on it that stick out further and it does work, should hold up better than the rubber. THanks
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
redleader
Parts Wanted
Nov 13, 2016 02:57 PM
Roadie
Feb 16, 2015 10:34 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
