Quest: 30mpg+ LT1 DD
Old Apr 29, 2008 | 12:20 PM
  #106
Ironxcross's Avatar
Originally Posted by shoebox
Higher vacuum means less load. You will use less fuel when the load is low.
so:
when im going 55 mph, and im fifth and the car is reading 2000 rpms, and there is almost no load on the motor... this is good?
compared to
when im going 55 mph, and im in sixth and the car is at 1400-1500 rpms and the motor feels a bit overwhelmed, this is bad?
Old Apr 29, 2008 | 03:08 PM
  #107
Mtxz453's Avatar
ive always wondered the same thing
Old Apr 29, 2008 | 03:12 PM
  #108
Ironxcross's Avatar
i think its time to get a vacuum gauge and find this out
Old Apr 29, 2008 | 04:25 PM
  #109
2QUIK6's Avatar
Not to mention that with a higher vacuum, the fuel pressure regulator makes the fp lower automatically. And at WOT when there is less vac, the fp is at its highest not to mention that the PE fueling tables are adding even more fuel
I'd be estatic if mine just got an average of 20mpg but my driving style would never allow that
Old Apr 30, 2008 | 12:01 AM
  #110
Malice 1's Avatar
I never did mileage comparisons when I had a vac gauge on v6 car. This is what I noticed though.
Cruising in 4th at 50mph, at 2000rpm, I was pulling 16" of vac, and the car idled at 17". A 10% increase in throttle got me to 13" and I got noticeagle acceleration.
Cruising in 5th gear at 50mph, at 1500rpm, I was pulling 15" of vac, and a 10% increase in throttle got me to about 9" without noticeable acceleration.
Old Apr 30, 2008 | 12:42 AM
  #111
Maverick_997's Avatar
im confused with the vacuum thing. the higher the number the beter the gas mileage or the lower the number the better the gas mileage??
Old Apr 30, 2008 | 01:16 AM
  #112
Malice 1's Avatar
higher vacuum means better mileage. 0 vacuum means you are at or close to wide open throttle.
high vacuum means your throttle blades are almost totally closed.
Old Apr 30, 2008 | 09:34 AM
  #113
2QUIK6's Avatar
I forgot to mention...my change in driving style to increase mileage consists of running stop signs and red lights and trying to never hit my brake Works pretty good....now if everyone else would at least learn not to prematurely brake all the time and get off their cell phones
Old Apr 30, 2008 | 03:52 PM
  #114
Mtxz453's Avatar
yea.. not sure if the running the stop sign thing is gonna help people out to much
Old Apr 30, 2008 | 05:36 PM
  #115
Ironxcross's Avatar
Yeah not so sure the running of the stop signs is the safest or most intelligent idea... but then again, you'll get really good mileage when you're dead.
Old Apr 30, 2008 | 06:23 PM
  #116
Car Enthusiast's Avatar
wait wait wait, you guys thought quik6 was being serious
Old May 19, 2008 | 06:49 PM
  #117
TasTe GOOD's Avatar
Any updates???
Old Jun 13, 2008 | 06:46 PM
  #118
Malice 1's Avatar
IT's been a while, but I've got some updates.
I installed GTS headlight covers for less drag(and because they look cool), some ASP underdrive pulleys, and a gizmo similar to a MAFT+ that lets me lean out my o2 sensors during closed loop. I also installed a vac gauge and a PLX wideband o2 sensor with gauge.
My previous best with windows up was 31.5mpg, and 30.9mpg as a backup test. My previous best windows down is 28.8mpg.
WIth the headlight covers, underdrive pulleys, and slightly leaned out o2's, I just pulled off 32.9mpg with the windows down. I can't do a windows up test because it's hot as hell in the south and my AC doesn't work. Once it's fixed, I imagine the UDP's will help out alot.
According to my wideband, the car used to cruise at 14.7-15.3AFR. I now have it set to cruise at 15.3-15.7 AFR. I dont' know if it's safe for the motor to cruise any leaner than that, so I'll probably leave it alone for a while.
EDIT: The car idles at 22" vac, and I try to accelerate between 10"-15". During cruise on level ground at 70mph, it will pull around 17". In these southern rolling hills, I cruise at 15"-20".
Old Jun 14, 2008 | 01:48 AM
  #119
AdioSS's Avatar
West South Central Moderator
that's very nice for a V8!
I've found that the biggest thing that I can do improve my fuel economy is to just drive slower. The other night I was driving my truck home on the highway and at the end of my trip the Average Fuel Economy reading was 25.7MPG. I drove like a 90 year old granny, but it paid off.
Old Jun 14, 2008 | 12:03 PM
  #120
sbs's Avatar
sbs
Originally Posted by Malice 1
...a gizmo similar to a MAFT+ that lets me lean out my o2 sensors during closed loop...
Tell us more of this gizmo. Got a link?
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
