Plug wires all the same or no?
Old May 5, 2010 | 05:20 PM
  #16
RECIPEFH's Avatar
I guess I will go to the TR55's with the Delco wires. Maybe simple is better in this case?
Old May 5, 2010 | 05:30 PM
  #17
z0s0's Avatar
Do it, you won't be sorry. I did the same setup a few weeks ago. Once you see how much fun it is to change the wires you'll be happier than a fat kid on a slippy slide that you didn't go with something bigger than the stock size (if you run them the same way as stock and use the stock looms). Anything larger wouldn't fit in the looms from what I can tell.
Old May 5, 2010 | 07:47 PM
  #18
FastandBlue's Avatar
So, new looms if I decide to go with larger wires, then? Or....???
Old May 5, 2010 | 07:52 PM
  #19
z0s0's Avatar
I think some of the guys on here have done the over-the-valve-cover routing using a kit you can buy when running thicker wires...but I'll leave the specifics to those who have done it.
Old May 5, 2010 | 07:57 PM
  #20
They look sharp on the car, but I am not sure I want to go that in depth right now. I know it's not hard, but it requires more $$$, something I would rather put into a high flow water pump and timing set.
Old May 5, 2010 | 10:05 PM
  #21
I ran Taylor 8mm Spiro-Pros, and they fit in all the factory clips, spacers, etc. But I didn't like the wires, so eventually I went back to the factory Packards. Currently have the 8.5mm MSD's, but I don't even use the Opti for anything but the optical sensor, so its sort of apples and oranges. The 8.5's are harder to fit in the stock routing, and may take a little Dremel work on the bracket that guides the wires around the passenger/front of the engine.
Old May 6, 2010 | 12:17 AM
  #22
MikeGyver's Avatar
You can drill out the 2 piece plug wire clamps for bigger wires. Securely hold the clamp closed with a vise when drilling or they will break.
Old May 6, 2010 | 01:16 AM
  #23
Fatdog2's Avatar
Stock wires are easier to put back into the looms.NGK plugs are the best.TR55's.Keep it simple.My02.Gapped at 50.
Old May 6, 2010 | 11:40 AM
  #24
Gotcha, alright, so I'm going to prolly go with:
8.5mm MSD Wires
NGK plugs TR55 gapped at 50.
Sound like a good setup?
Old May 6, 2010 | 11:48 AM
  #25
Mikes 1994 z28's Avatar
Have fun routing the MSD 8.5's. They are a pain in the *** and they dont fit the stock guide plate behind the power steering pump. I replaced my MSD's with Taylor 8mm Spiro-Pros 2 weeks ago and am very happy I did. The boots snap in better and they are lower profile compared to the fat msd boots that make it a bitch to route.
Old May 6, 2010 | 12:05 PM
  #26
You should only gap the TR55's to 0.050" if they are the platinum or iridium plugs. Copper plugs will burn up faster and open the gap up faster. Consider 0.035" - 0.040" for the non-Plat/Irid plugs
Old May 6, 2010 | 12:36 PM
  #27
charliediss's Avatar
I am currently running the Taylor 8.5s with OTVC wire looms purchased from Summit. Since I had to make my own wires, I decided to take the extra couple of hours and do it right this time around, it really paid off! I ended up going with the NGK TR55's and to be perfectly honest I have not seen a difference between those and the Bosch platnums. I have heard that anything above 1 electorde is a waste of money...however I THINK I heard something about there being some kind of tech advantage in the center electrode?
Old May 6, 2010 | 12:43 PM
  #28
Lol, thanks injuneer. I'll do that, then.
Yeah, I have a dremel though, so I don't mind routing them that way. But I guess while I am at it, I might as well ask. If I DO DECIDE to go with an over the valve cover routing, is there a kit you would recommend?
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
grabbem88
Mar 18, 2015 01:25 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
grgguy
17
Feb 23, 2015 07:57 PM
