Parasitic HP loss
Old Oct 4, 2006 | 05:41 PM
Skeeterz28's Avatar
Parasitic HP loss
Approximately how much hp would I reclaim with a lightweight flywheel and aluminum driveshaft with the mods in sig? 15-20?
Thanks in advance.
Old Oct 4, 2006 | 06:41 PM
black97z28LT1's Avatar
Re: Parasitic HP loss
Im curious of the aluminum drive shafter too
Here's a dyno test for an aluminum DS.... 1.1 peak HP and 5 lb-ft.
http://www.ws6.com/mod-1.htm
Old Oct 5, 2006 | 08:55 PM
haha...thanks Injuneer, well i guess i can atleast count on droppin a few pounds by switchin, lol
Old Oct 5, 2006 | 11:25 PM
HardcoreRM125's Avatar
The flywheel will help make it rev a little quicker. Its not going to give you big gains in power though. Just more "rev-happy" I would think. That seems to be how my experience with the whole lightwieght flywheel goes.
Old Oct 6, 2006 | 05:59 PM
Skeeterz28's Avatar
Thanks to all who replied.
Old Oct 6, 2006 | 08:08 PM
teke184's Avatar
the flywheel lets it rev up faster due to less rotational mass to spin, which in turn requires less power.
and if you gain 5# torque from spinning a driveshaft that is only 3" in diameter, imagine what 15lbs of mass reduction on an 11" wide flywheel will do.
i felt it made my car quite a bit faster accelerating. but it is a bit tricky to launch. but then again...i have a spec4 clutch which is a solid disc...not much slip when engaging the clutch
Old Oct 7, 2006 | 09:47 AM
who slips it....just get some sticky tires on there and drop the sum-bitch!
Nutty's96
Dec 21, 2015 06:25 AM
Girrrrl
Aug 20, 2015 09:26 AM
Girrrrl
Aug 20, 2015 06:17 AM
BlackSixSpeed
N2O Tech
Jan 2, 2003 11:29 PM
Mister Will
Nov 22, 2002 10:00 AM
