Opti delete
Old Aug 2, 2010 | 09:27 AM
  #46
S10Wildside's Avatar
Originally Posted by plattted
Does the $1600.00 price include the throttle body?
Your existing throttle body will work just fine.
Will it need a MAF sensor?
Only if you want to use a MAF sensor. The LS1 PCM can run in speed density mode. MAF sensor is not included and not required.
a new air lid with filter, is that included?
No, you don't need a new air intake to use the LS1 PCM.
It does sound good but all these additional pieces---
These additional prices you're referring to are unrelated/unnecessary to swapping to the LS1 PCM.
the '93 does not have a crank shaft key on the ballancer hub, not sure about the crank gear though.
There is a key to hold the crank timing sprocket. You simply have to install a 96-97 crank key to hold the reluctor in place.
Old Aug 2, 2010 | 09:31 AM
  #47
funina91ss's Avatar
Man I am glad you cam in to answer all that. I was about to post I don't work for them lol.
Old Dec 14, 2010 | 09:27 PM
  #48
user 647483's Avatar
Re: Opti delete
Thank you for sharing
Your pics were very helpful.
Old Dec 15, 2010 | 12:45 PM
  #49
mzgp5x's Avatar
Re: Opti delete
Does the stock LT1 MAF sensor work with the 24x EFI_connection system?
Old Dec 15, 2010 | 09:54 PM
  #50
Re: Opti delete
I'm pretty sure that the LT1 and LS1 MAF sensors were similar, to the extent that GM now has a single, less expensive part # that is a replacement for both the LT1 and LS1.
Old Feb 18, 2011 | 07:39 PM
  #51
merim123's Avatar
Re: Opti delete
hey guys, did you get a chance to do the pinout diagram. I have alldata and can see both, but it would be nice in a grid on one page to make the repin easier, exist anywhere yet?
Old Feb 18, 2011 | 09:14 PM
  #52
funina91ss's Avatar
Re: Opti delete
I haven't messed with it and don't know if I will ever be able to do so unless I do another swap.
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
tdigger9899
Sep 7, 2015 10:56 AM
tnmotown
Aug 10, 2015 11:52 PM
asilomar244
Jul 12, 2015 05:53 AM
