oil pump ?
Old Jul 3, 2007 | 08:14 AM
Fast4thGen's Avatar
oil pump ?
I read all the posts about using a hv oil pump on a stock pan, im confused now about what one to use. I think most people are saying to use the Melling select, but ive looked on summits web site and cant find one for our cars. I know we can use some gen1 parts but is the pump and pick up one of those parts. Can anybody post a link or a part number for the pump and the pickup. Also do you install the white spring in the select or leve it alone. Thanks for the help
Old Jul 5, 2007 | 11:34 AM
Fast4thGen's Avatar
come on guys, any help?
Old Jul 5, 2007 | 12:01 PM
Dave89IROC's Avatar
oil pump is the same as a gen 1, so yes, use the select oil pump for a gen 1 sbc
Old Jul 5, 2007 | 12:46 PM
96LT1TX's Avatar
stock pump/pickup for me, welded the intake to it. But then again, I have stock oil pan.
Old Jul 5, 2007 | 01:17 PM
...and use the white spring...
Old Jul 5, 2007 | 05:54 PM
I've seen the stock LT1 pump (bluprinted), tack-welded pickup and white spring support over 1,000HP in an LT1 using a stock pan and a windage tray. I use the same setup in my stroker.
Old Jul 5, 2007 | 06:15 PM
Phatcaprice's Avatar
Do you by any chance know what the different color springs represent? I've done a search on google and nothing turns up. I have a pink one in my melling.
Old Jul 5, 2007 | 06:38 PM
rskrause's Avatar
Moderator
Stock pump is fine.
Rich
Old Jul 5, 2007 | 10:22 PM
Fast4thGen's Avatar
Thanks guys, gonna order the melling select and use the white spring. Cant wait to get my set up finished up
Old Jul 5, 2007 | 10:55 PM
n2ceptor's Avatar
Question????/ Which is best; 5/8" or 3/4" screen??????? Does it matter???
Old Jul 5, 2007 | 11:04 PM
In the 1994 model year GM changed from the 5/8 to a 3/4 inlet pump for the LT1. I assumed it was to give it a little more volume available at any given moment. I don't have any data stating which is "better".
Old Jul 6, 2007 | 12:00 AM
2QUIK6's Avatar
Here's the thread I started a few weeks ago with the same confusion...ended upgetting all the parts in my original post.
http://web.camaross.com/forums/showthread.php?t=526820
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 07:11 PM
KYWes
Apr 15, 2015 05:48 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
NEWBIE T/A
Jun 14, 2002 12:27 AM
