oil pressure problems...again
Old Apr 8, 2007 | 07:22 PM
  #16
rskrause's Avatar
Moderator
Clogged screen is a distinct possibility on a new build.
Rich
Old Apr 8, 2007 | 09:19 PM
  #17
DirtyDaveW's Avatar
If you've replaced your oil pump with a Melling since Jan 2004 or are planning on replacing it, better read this first... NOT good!
http://www.nastyz28.com/forum/showthread.php?t=65870
I've ran across several boards that are talking about this.
David K. Wilson
Old Apr 9, 2007 | 05:11 PM
  #18
96LT1TX's Avatar
it is a OEM oil pump, bought at the local GM parts store (scoggin dickey).
http://www.sdparts.com/product/12555...vyOilPump.aspx
as far as I can tell it is the bone stock oil pump.
The screen makes me think, I still havent pulled the oil pan, the high has been like 38 degrees every day since I had time. I did put gasket maker over everything for the first time ever to get rid of an oil leak w/ my oil pan, so I am hoping this is a more likely problem. The screen wasnt clogged however when I put it in a little over 15 miles ago. I have never seen anything more than dust particles of metal in the oil, so I dont think it is something very serious. The oil pressure just NEEDS to be fixed and I really would hate to spend 350$ and not fix it.
so any problems w/ having that oil pump, stock pan, no windage tray. I have an OEM windage tray I could install to help oil flow (if it would?) but any more advice is appreciated.
Old Apr 9, 2007 | 07:14 PM
  #19
DirtyDaveW's Avatar
As much as you've spent, you'll be doing yourself a favor by going to the Canton pan/pickup. It will provide plenty of oil and will absolutely cure the oil pressure issue at WOT.
Old Apr 9, 2007 | 10:39 PM
  #20
96LT1TX's Avatar
sounds good to me. ebay time.
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
