Oil Pressure
Old Jul 14, 2007 | 09:41 AM
blk96z07's Avatar
Unhappy Oil Pressure
my oil pressure gauge is pegged on the other side so i cant see what my oil pressure is. so when i went to look under the hood went to the back of the block and the wire that goes to the plug that goes in in the sensor is ripped out!! so now i have no oil pressure the wire for the plug is out.how can i fix this so i can get oil pressure again? the wire is there and when i unplugged the sensor i didnt see where the wire went into or anything.
Old Jul 14, 2007 | 09:59 AM
Which side is the "other side" ? Do you mean its all the way over on the highest reading? That would be a sign the wire is disconnected. You probably actually have oil pressure, you just need to connect the wire. If "ripped out" means the wire/harness connector can no longer be connected to the sensor, you need a new sensor. If it means the wire is pulled out of the harness connector, you need a new "pigtail" (short length of wire with a new connector - part # on Shoebox's site).
http://shbox.com/1/op_sensor.jpg
http://shbox.com/1/Parts.htm
Old Jul 14, 2007 | 10:06 AM
blk96z07's Avatar
my bad the other side meaning the highest reading im sorry. the wire the goes into the harness connector is ripped out.so maybe a new pigtail i cant seem to find 1?
Old Jul 14, 2007 | 10:11 AM
Did you look at the second link? Its got the AC part # listed.
Old Jul 14, 2007 | 10:19 AM
blk96z07's Avatar
yes i did the part number is 12085499 for gm right? can i got anywhere to buy this pigtail snice i got the part numbers. btw the way the one on the website got 2 wires i think im got 1
Old Jul 14, 2007 | 11:02 AM
There is only one wire. The "other" wire you see is a shadow from the flash. I guess I need to edit out the shadow, even though it says there is only one wire.
[edit]shadow removed.
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
