383 stroker questions
Old Jul 12, 2007 | 06:20 PM
Bails098's Avatar
I have a 383 stroker edelbrock heads, cam, intake and a 150 shot of nitrous im wondering what size injectors i should use for this setup.
Old Jul 12, 2007 | 06:23 PM
FeelTheSpeed's Avatar
make sure you go big enough for that 150 shot, I couldn't tell you how big to go, but I'm sure a tuner could.
Old Jul 12, 2007 | 07:53 PM
LT-x7's Avatar
That only matters if it's a dry shot, wet kits provide there own fuel.
Is the 150 shot dry, or wet?
Old Jul 13, 2007 | 05:52 PM
Take your NA (no nitrous) flywheel HP, and multiply it by 0.07 That will give you the smallest injector you should consider. Generally, the LT1 dry kits raise the fuel pressure when you spray, so you size injectors for NA HP. If you have some other kind of dry kit, you'll have to let us know how it works.
Old Jul 14, 2007 | 11:22 AM
Bails098's Avatar
I have an edelbrock dry shot and it has a booster fuel pump.
D1SC383LT4
Jan 1, 2016 01:56 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Killer94z
Jan 13, 2015 12:06 PM
spearous
Jan 12, 2015 11:03 AM
