od of lt1 steam pipe
Old Nov 19, 2018 | 12:32 AM
racer96's Avatar
hey guys, going to do a stand up radiator and was going to get griffin to install a barb fitting in the radiator to just run the steam pipe directly into it. what size bung would i need. is it a 3/8 od diameter barb fitting or is it a 7/16 od barb fitting. thanks
Old Nov 19, 2018 | 08:31 AM
Re: od of lt1 steam pipe
I'd say 3/8, since that is the size vacuum cap I used to seal off the TB pipes when doing the TB bypass.
Old Nov 19, 2018 | 10:40 AM
Griffin should know that info. I have an LT1-specific Griffin, and it has a factory-matching connection for the steam pipe. If you believe the factory manual, the stock radiator has a vapor/liquid separator behind that connection. I don’t know if the Griffin includes that detail.
dabeastz28
Jul 22, 2010 09:19 AM
BahN
May 30, 2010 08:27 AM
FireChicken1995
Aug 6, 2007 11:57 PM
lethalz
Jan 9, 2005 12:29 AM
