steam pipe relocation for griffin
Old Jul 20, 2010 | 08:21 PM
dabeastz28's Avatar
hi need help with new rad its a commonly used griffin rad only comes with upper and lower hose and overflow i need to either weld fitting on under the cap fro steam pipe or can i move it where the bleeder valve on the t stat housing is with a bard or is there any other option for this please help thanks names joe
Old Jul 21, 2010 | 05:13 AM
The stock radiator suposedly has a "water/vapor separator" inside the end tank at the steam pipe connection. I bought a Griffin LT1 radiator, and it has the same provisions. You have to find a way to return the line to the radiator.
Old Jul 21, 2010 | 07:40 PM
chevyrules85's Avatar
i tied it into where the top bleeder was, and it seems to be doing fine, idk if you can see it here or not tho
https://www.camaroz28.com/forums/sho...d.php?t=762331
Old Jul 22, 2010 | 09:19 AM
Chaos1187's Avatar
I would imagine a tap and drill set with a size that fits your application, mount a threaded piece and adapter for the steam pipe but before connecting anything flush the radiator for any debris that would have gotten inside. Not sure if this is possible or it just sounds nice. Good Luck
RUENUF
Mar 13, 2016 03:37 PM
generaldave
Sep 25, 2015 06:48 PM
Devinfoote87
Jul 30, 2015 09:54 AM
Jlo
Jul 29, 2015 03:52 PM
realistyc
Jul 28, 2015 07:32 PM
