Steam Pipe Question
Old May 29, 2010 | 03:14 PM
BahN's Avatar
Steam Pipe Question
Hey guys, I have an LT1 swapped into a 3rd gen trans am. I wanted to run this by everyone and see if this is a problem. I currently do not have heat on the car yet, so the heat return line is capped on the waterpump. Now my radiator hose dosnt have a spot for the steam pipe, can i just hook the heat pressure line into the steam pipe directly? Or will this cause problems like the pump working agaisnt its self?
Thanks!
Old May 29, 2010 | 04:35 PM
The LT1 radiator has a connection for the steam pipe (93-94 goes directly there, 95-97 goes through the throttle body first). Inside the connection on the radiator is supposed to be some sort of liquid-vapor separator. You might want to consider using the LT1 radiator on your 3rd Gen, so you can run the system the way it was designed.
Lacking that, you want to connect the steam return to the lowest pressure point you can find, which means a line that returns to the radiator.
Old May 30, 2010 | 12:36 AM
MikeGyver's Avatar
Doesn't the steam line connect (and output) to the top of the radiator by the cap?
Old May 30, 2010 | 08:27 AM
Yes - "The LT1 radiator has a connection for the steam pipe (93-94 goes directly there, 95-97 goes through the throttle body first). "
He has a 3rd Gen, so there's no steam pipe connection.
http://shbox.com/1/93-94_hoses.jpg
http://shbox.com/1/95-97_hoses.jpg
That's why using an LT1 radiator is the first choice.
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
alphaauto
Parts Wanted
Jan 23, 2015 06:17 PM
Jazsun
Dec 29, 2014 12:14 PM
86ZZ4
Aug 22, 2002 08:50 AM
