Octane Question?
Old Jul 9, 2006 | 11:20 AM
saxmo's Avatar
Octane Question?
does anyone know where I can get some information on octane needs for performance engines? I bought an LT1 that has about 570 n/a at flywheel with 3.5 crank and 12.8:1 compression. I was told it was built for alcohol, but I am wanting to make it more streetable. I need info, so I can figure out how I can run on pump gas.
Old Jul 9, 2006 | 12:13 PM
Re: Octane Question?
Octane requirements are determined largely by "dynamic compression ratio", not be static compression ratio. Do a "search" an "octane" and "DCR" and you should be able to find discussions of the DCR limits for various types of fuel.
Old Jul 9, 2006 | 02:30 PM
nittanylionlt1's Avatar
You'll probably have to change some gaskets as well.
Old Jul 9, 2006 | 03:15 PM
saxmo's Avatar
yeah, I know the heagaskets are .018, so I have some room there to lower the compression.
Old Jul 9, 2006 | 03:18 PM
saxmo's Avatar
I have done some searches.. and have found a few articles that, in summation, state to try different octanes until pre-detonation stops... then adjust the power with timing.
DirtyDaveW
Mar 15, 2015 07:01 PM
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
