Obdi or obdii???
Old Feb 27, 2010 | 11:20 PM
z28beast's Avatar
Obdi or obdii???
ok so i have a1994 z28 and im pretty sure its obdI..i plan on building up my camaro but i dont know if its worth it because its obdI..and i have heard that its outdated. my question is this..is obd1 better than obd2 or is obd1 a good system for building my car on..also is there any way to convert to obd2?
Old Feb 28, 2010 | 07:17 AM
AL SS590 M6's Avatar
Moderator
This is soooooooo in the wrong forum. I'm going to move it to LT1/4 Tech.
Old Feb 28, 2010 | 07:29 AM
Guest47904's Avatar
Guest
Of the 2, OBDI is by far easier to modify without running into obstacles but gives you just as good control. Yes 93 - 95 was OBDI. Stick with your 94. 95 is bastard child in that it has OBDI control with a OBDII connector. For me, the Snap-on Solus deals with it all but others have had issues. Particularly those id^&ts at AZ that try to read them with their OBDII scanners.
OBDII monitors more things that you will only find a nuisance. Like misfires and cat health.
I suggest you become familiar with scanners, able to deal with OBDI in an F body. Not merely code readers. In your day to day dealings with this OLD chassis, you will inevitably run into a running issue. A code reader is OK at best. You should have a scanner that can read real time signals from sensors. Very helpful.
You need to talk to Shoebox about that cam you plan on using. I think he has the same cam. He can give you advice better than anyone with regard to using it.
Old Feb 28, 2010 | 10:29 AM
It is not "outdated" unless you have an intense love of emissions control systems. There are only very subtle differences between the OBD-I and OBD-II means and methods of controlling the LT1 engine. The major difference is the fact that OBD-II added numerous checks on the performance of the emissions systems. They didn't change anything that really affects the performance of the engine. A minor issue with controlling the 4L60E with very high stall torque converters.... but that's not usually an issue, and people have developed work-arounds.
Do not convert to OBD-II. Many people with OBD-II (96 ane 97 only) convert to OBD-I, because of the availability of cheap/free scanning software, cheap tuning software, less issues with a multiplicity of emissions codes, etc.
Old Feb 28, 2010 | 11:53 AM
z28beast's Avatar
ok bro..thanks for all the help
aj2494
Mar 12, 2015 10:17 PM
ollie-99
Feb 10, 2003 12:48 PM
SnkEatr
Feb 9, 2003 09:56 PM
96z
Feb 6, 2003 03:23 PM
blackhawk96
V6 Tech
Aug 27, 2002 07:17 AM
