NO FUEL PRESSURE need help!!!!
Old Apr 21, 2004 | 01:11 PM
1994TransAm's Avatar
i have no fuel pressure... at all....
hooked up the guage... nothing.....
what do i do next!!!!!!!!!
Old Apr 21, 2004 | 01:15 PM
turbo_Z's Avatar
do you hear the fuel pump humming in the rear with the key turned to the ON position? does fuel squirt out of the valve on the fuel lines?
Old Apr 21, 2004 | 01:20 PM
no humming
i'm gonna jump the pump....if that doesnt work.... gotta pull the pump!!!
Old Apr 21, 2004 | 01:21 PM
turbo_Z's Avatar
might be a fuse to that pump.. id look for that first. i know there is one for the injectors so its possible theres one for the pump as well.
Old Apr 21, 2004 | 01:37 PM
i disconnected the fuel lines... and turned the ignition on.... nothing came out except for a lil spillage!!!
i tried to prime the pump...... nothing........
anyone know a good fule pump install page... the over the seat kind!!!
Old Apr 21, 2004 | 02:21 PM
IDOXLR8's Avatar
As stated earlier did you try the fuse?
Old Apr 21, 2004 | 04:17 PM
How did you try and prime the pump - with the gray connector under the hood? Did you check to make sure the fuel pump relay isn't bad..... a lot easier to change than the pump.
Old Apr 21, 2004 | 05:06 PM
valter's Avatar
As Injuneer said. Relay or fuse can be bad. I'd try priming pump just simulating relay. Unfortunately that was not my case - at least there is no anti-siphon stuff in Crown Vic's gas tank
Old Apr 21, 2004 | 10:29 PM
HBHRacing's Avatar
follow this link a little ways down is No start, no fuel diagnostics..
http://mainstreamtopics.com/forum/in...p?showtopic=78
Old Apr 23, 2004 | 01:11 AM
even if the relay was bad.... woldnt the primer connection near the pcm jump the pump?
i have a new relay and the car still doesnt run.... i just cut a huge hole in my floor board too for the pump!!!!
Old Apr 23, 2004 | 10:57 AM
HBHRacing's Avatar
the prime connector is a direct line to the pump. if you jump that to hot it will send voltage back good relay or not.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
