NO FUEL PRESSURE need help!!!!
i disconnected the fuel lines... and turned the ignition on.... nothing came out except for a lil spillage!!!
i tried to prime the pump...... nothing........
anyone know a good fule pump install page... the over the seat kind!!!
How did you try and prime the pump - with the gray connector under the hood? Did you check to make sure the fuel pump relay isn't bad..... a lot easier to change than the pump.
follow this link a little ways down is No start, no fuel diagnostics..
http://mainstreamtopics.com/forum/in...p?showtopic=78
even if the relay was bad.... woldnt the primer connection near the pcm jump the pump?
i have a new relay and the car still doesnt run.... i just cut a huge hole in my floor board too for the pump!!!!
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
