New Plugs And Wires???
Old Sep 9, 2003 | 08:37 PM
Z28Boss's Avatar
Angry New Plugs And Wires???
I have a question. My opti went bad and I just changed that. I had a rough idle before and it is still there. Can having a bad opti damage your plugs and wires?? Could it be that I need to replace those now to finish the problem off?? Please let me know what you think, I replaced my IAT sensor and cleaned the throttle body and cleaned the IAC valve and that took care of my low RPM hesitation. I just need to get rid of that rough idle now. Thanks!!
Old Sep 10, 2003 | 05:33 PM
Z28Boss's Avatar
Come on now fellas, there has to be someone out there who knows about this stuff. Hello..................echo echo echo. Ok now I am just being dumb, but seriously, anybody??
Old Sep 10, 2003 | 05:36 PM
NiteRider's Avatar
I think it's more so the other way, bad wires might **** up the opti. Either way if your in doubt change them up they might have burnt from a previous instal or just gone bad over time. Also change ignition coil.
Old Sep 10, 2003 | 05:46 PM
Z28Boss's Avatar
Thanks man, at least ya gave me some info. I will probably have to change them. I plan to use AC Delco plats again but what about wires?? Keep the info coming guys. Thanks!!!
Old Sep 10, 2003 | 05:50 PM
NiteRider's Avatar
Go with Taylor 8mm's. You can still run them thru the stock looms that way.
Old Sep 11, 2003 | 07:16 AM
Z28Boss's Avatar
Hey niterider, I saw you have a MSD blaster coil, do those really make that big of a difference?? Please let me know.
PCLZ28
Dec 24, 2015 05:19 PM
charchri4
Apr 14, 2015 06:40 PM
eanhl2004
Apr 4, 2015 12:01 PM
IRABuss
Sep 7, 2011 09:08 PM
gh0st
Sep 1, 2002 10:24 AM
