View Poll Results: Is it my starter thats going out ?
STARTER ?
100.00%
WIRE FROM THE STARTER GOING OUT
0%
OTHER ?
0%
Voters: 5. You may not vote on this poll
New Optima battery but bad starter HELP !
Old Dec 12, 2008 | 04:05 PM
Camaro4thgenss's Avatar
Ok before I put in a brand new red top battery my 97 for the past year had problems starting.. it wouldn't stall but it woudlnt start up like a brand new car does . " easy way to explain the starting "
So i put in a new opti battery and yesturday it started up then i turned it off.... and went to start it again, it would not crank it just made a THUNK SOUND that was all... I tried a few hours later same thing I was like wtf... Im not a mechanic and only know so much about cars. I checked the wires up top everything was connected.
So i went out to my car this morning and it started up.... I drove it to my friends work and it died " he knows ALOT about LT1, hes built them and so forth from scratch.
When he went to turn it on it started to smoke a little bit on passenger side header below engine. He believes ITS THE STARTER......
3 Hours later today it started up not easy but started i drove it home and its dead again. so the question is DO YOU THINK ITS THE STARTER ?
Old Dec 12, 2008 | 05:06 PM
CrashnBurn's Avatar
sounds similar to when my starter went out. if it is the starter its not that big of a deal..EASY FIX autozone has a remaned starter for cheap and you get like 40 off for your old starter....and its very easy to swap out yourself. Oh yah look at different year starters 93-97 will all work on the LT1 but the 96 is the best deal, yes they are different prices significantly in some cases
Old Dec 12, 2008 | 05:15 PM
Auto zone here in az has them for $139.99 + $40.00 core charge.
Ive dumped sooo much money into this car in the past year im getting sick of it.
OPTI...... worst idea / place to put one on the LT1 its evil lol
Old Dec 13, 2008 | 05:07 AM
CrashnBurn's Avatar
take your starter out then take it to autozone...itll be 100 even...also like i said check the 96' model i think that was the best deal...again they all bolt up..and the 96' is the LT4 design...as stupid as it may seem it sounds cool starting it lol....starts faster too
Old Dec 13, 2008 | 05:31 AM
bombebomb's Avatar
Atleast the starter is an easy fix.
Your money pit err I mean camaro, has just begun spending your money
Old Dec 13, 2008 | 07:12 AM
whammer33024's Avatar
i believe he will spend 180 and when he brings his old starter back he will get the 40 back for it
Old Dec 13, 2008 | 11:04 AM
CrashnBurn's Avatar
odd i just looked at autozone and its 149 with a 32 core charge......and they are only showin 1 style starter...i just replaced mine a couple months ago...anyway...do a search on the boards about starters and go with a LT4 style...it starts a lot easier and faster
Old Dec 13, 2008 | 11:07 AM
My Red 93Z-28's Avatar
yep.
Depending on whats wrong with it, you can have it rebuilt, but for peace of mind, you might as well go ahead and buy the reman.
Old Dec 13, 2008 | 04:01 PM
This is my second LT1.... The car is .40 over 357 lt4 set up #30 svo injectors pcm4less tune Headers / magna flow exhust, electric water pump, 58 mm and so on ... on the dyno it put down 343 hp and 361 tq
Since januray ive
1. new clutch went from spec stage 3 to ram clutch
2. 2 opti sparks 1 recentley
ive spent over $2 k .... to have it all installed... THIS YEAR
I HATE OPTIS so im not a stranger to when it comes to **** breaking and putting it in
Old Aug 2, 2010 | 11:51 PM
lildemars09's Avatar
you have put an opti in? shoot me some pointer if you would before i tackle the project. im hoping to have it done by wednesday before work. mine is not working and i ordered the one from summit for 260 and it comes in today and i want to start on it Wednesday. in addition, theres got to be a way for these opti to stop breaking like they are now. its the heat from the engine thats killing them isnt it?
Since januray ive
Old Aug 3, 2010 | 09:07 PM
Final03's Avatar
Its a pain to install....
You need to remove raidiator/watermpump/fans/harmonic balancer pulley....
then you should be able to get to it pretty easliy... def a pain though...
AlaskaZ28
Apr 17, 2015 08:54 AM
eanhl2004
Apr 4, 2015 12:01 PM
robcarnut
Mar 20, 2015 03:40 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
97z28k&N
Jan 9, 2015 04:58 AM
