New LE3 setup Dyno numbers
Old May 8, 2005 | 02:16 PM
  #31
Showme's Avatar
Re: New LE3 setup Dyno numbers
Great Numbers Man,
I almost went with the LE3 cam, but punked out because I thought it would have been too much for car on the streets and thought I'd have to rev too high to see its full potential....I was wrong When this stock engine goes, I will be getting that cam in a 383!
Congratulations!!!!
Tim
Old May 8, 2005 | 02:39 PM
  #32
bunker's Avatar
Originally Posted by madwolf
OBD2s don't upload as fast as LS1s. They are quicker but not by a whole lot. At least not enough to justify converting to OBD2. You might make a few HP less with the OBD2 as well and you will need to re-do your WOT air fuel ratio.
There are no more options in the OBD2 either and it's not closer to tuning an LS1. It's pretty much the same as OBD1 with a few differences.
Are you running a 58mm TB by the way?
I thought it would be half the time because it only does one part of the flash not the whoel T/E side I guess you would call it, just the e side? Anyways I heard just half is uploaded reducing the time by half.
If there are no more options in OBDII then I guess screw it, I thought there would be Ok LS1 conversion on LT1, change firing order and add a few sensors
Old May 8, 2005 | 03:19 PM
  #33
madwolf's Avatar
No, OBD2 LT1 doesn't do segmented uploading like LS1 does. The read is slower than OBD1 and the write is just a bit faster. It rewrites both E and T sides. The T side is twice bigger than on OBD1, but it writes it twice quicker. The E side writes the same as on OBD1, so you get 75% quicker overall.
If you want your car to set more codes (that you will disable) than your OBD1, then I guess you could call it an extra option if you want, because there isn't much else different than OBD1.
I wish you good luck on the LS1 conversion.
Old May 8, 2005 | 03:55 PM
  #34
bunker's Avatar
Wow thanx for the info I guess screw it then, LS1 conversion it is
Old May 8, 2005 | 06:42 PM
  #35
93formula's Avatar
yup
Old May 8, 2005 | 08:20 PM
  #36
Hybrid86Z's Avatar
damn nice numbers.
i'm still debating on either the LE3 cam or the LE2 cam.....hrm.....I will be getting the LE3 heads though.
I will have to talk to Lloyd again sometime about which cam to get lol
-Ben
Old May 8, 2005 | 08:36 PM
  #37
Joes94TA's Avatar
Very good numbers for stock bottom end...
Oldss I seen 2 of your cams you didnt change that much big guy...LOL
Old May 8, 2005 | 10:05 PM
  #38
97Z-M6's Avatar
god i cant wait to get my joe o cam on my 355 with loyd le3 heads. my cam is a bit bigger than the le3.
i hate these post becasuse they make me impaitent on my build up.
congrats bunker very impressive
Old May 9, 2005 | 09:28 AM
  #39
LT4POWR's Avatar
Good job!!!
Old May 9, 2005 | 09:52 AM
  #40
WS Sick's Avatar
Very nice numbers . We need to see it translate to the track now. I can't wait it should run very well !!
I thought the 12 bolt only ate like 4 or 5 more HP than the 7.5?
Old May 15, 2005 | 08:01 PM
  #41
93formula's Avatar
well took a ghetto pic of the dyno sheet with my digi cam:
http://www.members.shaw.ca/roynaidu/Picture%20002.jpg
Old May 15, 2005 | 08:35 PM
  #42
blackz97's Avatar
That picture actually came out really good, i can read the graph clear as day. HOLY SMOKES!
Steve
Old May 15, 2005 | 09:39 PM
  #43
Zigroid's Avatar
that graph looks like you gained some low(er) end torque after swapping cams from your old setup, is that true? what was your old setup?
Old May 16, 2005 | 02:01 AM
  #44
bunker's Avatar
If you're looking at 377rwhp numbers thats with a closed cut-out through a bone stock muffler for one of the runs just to see what would happen LOL.
Old May 16, 2005 | 02:10 AM
  #45
93formula's Avatar
woot stock muffler supports 377 hp, LOL
DirtyDaveW
Dec 1, 2016 05:37 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
Red_94Formula
Jan 22, 2015 12:17 AM
97 RedSS
Jun 10, 2003 07:58 PM
Joe Brodman
Jul 24, 2002 05:24 AM
