How much to shave off of head for a 12:1 comp..LT1
Old May 15, 2005 | 09:39 PM
wb3s94z28's Avatar
What thickness gasket and how much should I deck an LT1 head if I want to raise the compression to a 12:1? Everything is stock...
Old May 16, 2005 | 02:58 AM
sssalah's Avatar
Re: How much to shave off of head for a 12:1 comp..LT1
Use the Impala gaskets, they're 0.029" compared to 0.049" stock. Generally for SBC removing 0.007" from the head is 1 cc. If your stock chambers are 55 cc then you'll need to go down to 48 cc, so you'll have to remove 0.049" from your heads and use the thinner gasket.
You can also deck the block for a thighter quench, and shave less from the heads.
PCLZ28
Dec 24, 2015 05:19 PM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Dec 28, 2014 06:20 PM
slothgrant
Aug 22, 2002 03:01 PM
