Need Help Bad!!!!!! Battery Relocation
OK i am just about to burn this CAR !!!!!
Put the battery in the back, to make room for the intercooler..
Ok this is what i have...
New red top- charger has been on it for the last few days to keep it up...
Power
00 welding cable FROM
bat to the kill switch
kill switch to the starter
starter to the power dis box on the fender ( this is 1 awg wire )
4 awg wire from the power box to alt..
Grounds
from bat to frame ( welded 3/8 bolt ) 1awg wire
from starter bolt to frame (welded bolt 3/8) ground strap
from bat to seat belt bolt 1 awg
from fender ground bolt to eng
eng to frame
Car would not start, the starter would click RAPIDLY. VERY fast.
i am out and done at this point....i don't no where to go with this.....
HELP ME
Power
Grounds
eng to frame
HELP ME
Re: Need Help Bad!!!!!! Battery Relocation
i did this as well
It was the small yellow/black wire from the Theft Deterrent Relay (TDR) to the BCM (body control module) which grounds the TDR through the BCM. So we just soldered on a "jumper" wire from the terminal at the TDR and grounded it to the factory grounding stud on the inside passenger door/closeout panel.
THe only diff this made was i could try and start the car with out the clutch...now i have to push the clutch in ....
black/white is probably the PCM ground that goes to the block........
courtesy of shoebox
http://shbox.com/1/starter.jpg
http://shbox.com/1/g103.jpg
courtesy of shoebox
I was thinking that..but the wire just fit on to the starter so that is where i put it....
i will put it to the block and see .....it has only been a 1 1/2 years with the car apart
Please post on the correct forum, and only on the correct forum. You've got this in 3 different locations, and it doesn't belong on Advanced Tech or on LT1/LT4 Engine Tech.
carguyshu
Jan 22, 2017 11:19 AM
eanhl2004
Apr 4, 2015 12:01 PM
