Name of this sensor ????
Old Nov 27, 2018 | 01:25 AM
Marshmaro's Avatar
I need the name of the sensor that goes into the water pump that tells yours fans to turn on when hot enough.. Thx guys !!! Is it this one ? https://www.rockauto.com/en/catalog/...+/+sensor,4748
Old Nov 27, 2018 | 06:23 AM
Re: Name of this sensor ????
No, that is the one for the gauge.
https://www.rockauto.com/en/moreinfo...3860&jsn=10484 is the one you want. They both are called Engine Coolant Temperature Sensor.
Old Nov 27, 2018 | 08:10 AM
And to clarify, the sensor in the water pump tells the PCM what the coolant temperature is. The PCM uses that info to turn on the fans, and for other purposes like cold start A/F ratio enrichment, switching the programming to closed loop, etc.
Old Nov 27, 2018 | 08:30 AM
Marshmaro's Avatar
Thank you for the clarification.......
I ordered the above part. Might as well since a new water pump is going in..
yournamehere
Oct 28, 2008 10:31 PM
lt1chevelle
Jul 7, 2007 07:05 PM
Beyonce Knowles
Jan 9, 2005 07:40 PM
got_hp?
Oct 14, 2003 08:03 PM
96 WS6
Feb 18, 2003 04:57 AM
